    Mame 2003 / Xarcade tank stick with Aimtrak autoconfig issues
    mame2003-plusxarcade2jstick
    1 Posts 1 Posters 199 Views
      a1084426
      with Mame 2003 or 2003+ when having a tankstick plugged in + Aimtrak Gun and light bar have issues when loaded mame 2003 roms aka Asteroids it re-configures the devices and the Gun seems to become Device 0 and then the player 1 is set on Joystick 2 on the tankstick and the config just gets all screwed around. Using Advmame version this does not happen and I can easily have it setup once and it stays put
      is there any point using mame 2003 over advmame on Raspberry with multiple USB input devices? as mame 2003 just seems to want to re-configure and switch them around a lot and cant get it to play nice, without removing the Aimtrak device and only having the tank stick installed
