    Auto mount USB HDD doesn't mount, HDD does work
    ext4usb hddauto mount
    4 Posts 2 Posters 807 Views
    • squishykoishiS
      squishykoishi
      Hello,
      I have followed the steps from the wiki to automatically mount my USB HDD (which is a 250GB SATA drive connected with an adaptor) and copy the (currently, mostly empty) RetroPie folders over after a reboot by creating the folder it requires.
      However although RetroPie does detect the USB HDD and I know it works when mounted, since I was able to make the folder using the RetroPie CLI, it doesn't seem to actually mount it at all on boot to the right directory it needs + copy the folder structure, for whatever reason I can't figure out for now.
      If any more info is needed please tell me to provide it, but some more info should be listed below that should be necessary:
      • Partition: /dev/sda1
      • File System: ext4 (formatted via gparted)
      • RetroPie version: 4.4 + updated all system packages via apt
      • Boot method for RetroPie OS: PINN 3.2 (I installed RetroPie from its menu)
      Thanks for any assistance. (Note that using the SD card, or using the manual way isn't that practical a solution. I'd rather not faff with /etc/fstab)
        Is the usbmount service installed and enabled ? Did you create the retropie-mount folder on the disk before inserting ?
        Why ? If you intend to have the disk mounted all the time, why not adding it to /etc/fstab - it's just one line and you don't need the usbmount service to be installed/enabled.
        • squishykoishiS
          squishykoishi
          Oddly it mounts fine using the same setup except formatted to FAT32 - it mounted itself when it booted ES after inserting the USB. Maybe I changed a setting of some sort, but at least it's working now.
          Not like I probably need to add files bigger than 4GB since I only plan to go as far as PS1 anyway... :P
          As for /etc/fstab I'd probably ask something pathetically stupid about it, and would rather not waste time for people who need to answer more important questions/fix bugs or whatever :p
            mitu Global Moderator @squishykoishi
            @squishykoishi said in Auto mount USB HDD doesn't mount, HDD does work:
            My local LUG had a motto - don't just ask to ask, ask directly. That's why the forum (including the Help & Support category) exists.
