    Problem with accessing retropie menu
    retropie menu
    16 Posts 3 Posters 1.2k Views
    • I
      idk
      So this is my first time posting. Everytime i go into the retropie menu and i try to go into anything like raspi-config, retropie setup. Basically everything in the retropie menu won’t work. It will just load and then kick me back to the retropie menu.
      Pi Model or other hardware: B+
      Power Supply used: Canakit power supply
      RetroPie Version Used: 4.2 I think, I can’t check
      Built From: Pre made SD image from official Retropie website
      USB Devices connected: none
      Controller used: PS4 Controller
      Error messages received: none
      • I
        idk @idk
        Also I know nothing about coding
        • I
          idk @idk
          PLEASE SOMEONE I NEED HELP
            Use a recent image - like the 4.4 release, 4.2 is over 2 years old.
            • I
              idk @mitu
              @mitu I can’t, I literally can’t even connect to wifi
              • I
                idk @idk
                Do i have to literally have to reinstall it on the sd card?
                  mitu Global Moderator @idk
                  @idk To install the 4.4 image, yes - you'll have to install it again on the SD card. You can backup your ROMs first - https://retropie.org.uk/docs/Updating-RetroPie/#making-a-backup-option-2 - then write the 4.4 image on the sdcard.
                  • I
                    idk @mitu
                    @mitu so im using a mac so how do i erase the stuff installed on the sd card
                      @idk How did you write the image in the first place ? https://retropie.org.uk/docs/First-Installation/#installation.
                      • I
                        idk @mitu
                        @mitu I downloaded the image from the retropie website and used etcher to install retropie on the microsd card
                          edmaul69 @idk
                          @idk you dont have to erase the card. When you install the new image, etcher will format the card.
                          • I
                            idk @edmaul69
                            @edmaul69 wouldn’t that mess up the micro sd card. Because there would be 2 retropies
                              edmaul69 @idk
                              @idk no. It completely formats the card erasing the old one.
                              • I
                                idk @edmaul69
                                @edmaul69 @mitu Ok. Thank you both for all of your help. Your the best
                                • I
                                  idk @idk
                                  Actually how do i update retropie
                                    @idk From the RetroPie-Setup menu entry in Emulationstation - https://retropie.org.uk/docs/Updating-RetroPie/.
