    [SOLVED] Configure a Wireless controller's index
    bluetooth udev
    3 Posts 2 Posters 373 Views
    • L
      linclms
      Hello everyone,
      Any idea on how to set a specific index for a bluetooth controller?
      I have two wired arcade joysticks and a bluetooth gamepad, and every time I turn on the bluetooth gamepad, it gets "index 0", taking over the wired joysticks.
      I wanted to force my bluetooth gamepad to be index 2, and keep my joystick1 as index 0, and joystick2 as index 1.
      I know I can customize the order under the configuration editor BUT the indexes themselves change as the bluetooth gamepad gets detected and that messes things up for me.
      Thank you!
        You can use @meleu's joystick selection utility, which can re-arrange the indexes by name - https://github.com/meleu/RetroPie-joystick-selection.
        • L
          linclms @mitu
          @mitu I don't think that works (though thank you for the suggestion).
          The problem is that my gamepad's number was dynamic so I wouldn't know what number it was until I start the game!
          Though I managed to solve the problem by creating a runcommand-onstart.sh script:
          root@retropie:/opt/retropie# cat /opt/retropie/configs/all/runcommand-onstart.sh
          #!/bin/bash
          # fix player input index order!
          # on my system, the bluetooth gamepad always gets index 0 when it is active
          # which messes up the controls for all joystick based games!
          if [ -e "/dev/input/js2" ]
          then
          # Bluetooth controller is currently active!
          # Change retroarch's config order for player 1 through 3...
          # wired joystick 1 for player 1, wired joystick 2 for player 2, wireless gamepad for player 3
          /bin/cp /opt/retropie/configs/all/base_configs/retroarch.cfg.all-bluetooth_enabled /opt/retropie/configs/all/retroarch.cfg
          # bluetooth gamepad for player 1, for psx!
          /bin/cp /opt/retropie/configs/all/base_configs/retroarch.cfg.psx-bluetooth_enabled /opt/retropie/configs/psx/retroarch.cfg
          else
          # Bluetooth controller not presently active!
          # Reset retroarch's config
          /bin/cp /opt/retropie/configs/all/base_configs/retroarch.cfg.all-bluetooth_disabled /opt/retropie/configs/all/retroarch.cfg
          # no custom input config for psx!
          /bin/cp /opt/retropie/configs/all/base_configs/retroarch.cfg.psx-bluetooth_disabled /opt/retropie/configs/psx/retroarch.cfg
          fi
          This is hardcoded to my system but it solves my problem!
          It looks for /dev/input/js2 (which is the device for my bluetooth gamepad) and, if it exists, it overwrites the retroarch.cfg global (and the psx) config to map the input_playerX_joypad_index parameter! :)
