    Wireless Xbox One controller issue!
    wireless controbluetooth problbluetooth issue
    3 Posts 3 Posters 667 Views
      Buzz229
      Hi everyone
      This is my first post. I'm trying to get the controller connected via bluetooth. It says registered and connected in the config, yet when I get back to RetroPie (settings area)and press the start button (or any button) on the controller it does nothing! The Model is a B+ and the version of RetroPie is the latest one on the website.
      Cheers
      • quicksilverQ
        quicksilver @Buzz229
        @Buzz229 which model of Xbox one controller are you using? Look under the battery cover. Is it a 1708?
        • H
          HipHopBlond
          Had the same issue with the Xbox One S controller.
          https://www.instructables.com/id/Fixed-Setup-for-Xbox-One-Bluetooth-Controller-With/
          This fixed it for me, but I suggest that you keep it connected via USB and ditch bluetooth.
          If you connect it back via USB cable (because you wanna charge it), once you're battery is charged, and you unplug it, you will have to remove it from devices and register it again... it's a pain in the butt.
