    Rgbcommander help
    rgbcommander
    2 Posts 2 Posters 387 Views
    • N
      neox666x
      Hi
      Setting up my cabinet with rgbcommander.
      At retropie the lights working fine but not in mame.
      By starting rom the lights turning off....
      Im using mame4all think its a Problem with the symlink or with the XML.
      Does anyone have the right usage for the mame4all settings for the xml?
      Thx....
        Purplehays86
        im having a similar issue but with advmame roms. I don't have any mame4all roms, but I'm guessing that our problems are similar. from what I am figuring out, it is a problem in the xml file.
        you might have to add something like
        <emulator binary="mame-mame4all" name="mame4all" active="Blue" inactive="DimGray" arcade="1" retropie="1" retropiebinary="mame4all" reference="arcade"/>
        to your xml file.
