    Scumm Problem
    scummretropielinux
    5 Posts 3 Posters 759 Views
      ray3d
      Hello had an olds image and I updated to the latest retropie. In specific with Scumm, when I try to load a game I receive the message:
      Error running game. Game data not found.
      Another thing I note the “launch gui” is not visible. I just see the list of games in Scumm. Is there a way to enable to view the launch gui, or in which file controls that one?
        BuZz administrators @ray3d
        @ray3d Please do not post a support request without first reading and following the advice in https://retropie.org.uk/forum/topic/3/read-this-first
        • EfriimE
          Efriim
          Here is the file that starts the scummvm gui, it should be in the \\roms\scummvm\ directory.
          +Start ScummVM.sh
          It is possible ownership of this file has changed somehow. Deleting this file and replacing or updating scummvm again should give it the right perms. You may need to use a terminal keyboard, press "F4" to exit to cmdline, or open a SSH.
          cd
          cd RetroPie/roms/scummvm
          sudo chown pi.pi "+Start ScummVM.sh"
          sudo chmod 744 "+Start ScummVM.sh"
            ray3d
            Ok thank you to watch. Now I have the error
            lvl0 error finding/creating file data for “”xxx””
            where xxx is not the actual message I entered to put here and is the route of the Scumm directory in the pigaming roms home directory. Any Idea?
            • EfriimE
              Efriim @ray3d
              @ray3d
              None idea, but also https://retropie.org.uk/forum/topic/3/read-this-first and update with more information.
