    Problem Amiga wdload
    amigawhdloadproblema
    2 Posts 2 Posters 223 Views
      gmasi1971
      Hi, forgive me for my non-perfect English.
      Until a few months ago I had a perfect backup of back surfaces that I absent-mindedly updated and I have a previous one.
      In the Backup that I did not do I had the amiga whload that started with the old method using the rom adf.
      Due to an error I had to restore the old backup and lost the whload part.
      I tried configuring the whdload files with the new method.
      Now the whloads run only with the lha (I can't find the rom versions of the adf anymore ... if anyone knows where to find them, it would give me great pleasure).
      The new method is easier to configure but there is one thing that I can no longer make work.
      In the old method, when a game started, the autoboot screen came up where you could set up the cheats.
      Now this is gone and the game starts directly.
      How do you start the autoboot and then be able to insert the cheats that are inside the game?
      Thanks for your help
      • thestargliderT
        thestarglider
        I remember having an issue before with Amiberry and trying to reset the autoboots of my games. If I remember correctly I fixed it by going to:
        /opt/retropie/configs/amiga/amiberry/whdboot/game-data
        And deleting the whdload_db.xml file from there (or you could manually go through the entire list and remove the entries you wish to show the bootloader for again).
        Obviously I would strongly suggest backing up the file first before deleting or editing it! I hope this helps!
        Starglider!!! From Rainbird!!!
