    [SOLVED]Problem with shanwan controller bluetooth connection on Retropie 4.4.12
    shanwansixaxiscustombluez4.4.12ps3 controller
    4 Posts 2 Posters 3.1k Views
    • 4
      4uvak91
      RetroPie Version Used: 4.4.12
      USB Devices connected: None
      Controller used: Shanwan PS3 controller
      Hi,
      This is my first post ever, usually I find answers from previous threads but this is an exception now.
      I haven't used my retropie in awhile and powered it on yesterday to check for updates. I updated RP to latest commit 4.4.12 without any issues BUT after the update I couldn't connect my third-party Shanwan controllers via bluetooth anymore. My previous setup was sixaxis + custombluez and it worked just fine. I tired to reinstall sixaxis + custombluez and reconnect, but it didn't work. The controllers however showed up in the device list. I also tried with ps3controller driver (with shanwan driver from config) but no luck. The controllers works just fine via cable. So any idea how to fix this, possibly manually?
      Thanks in advance.
        mitu Global Moderator @4uvak91
        @4uvak91 there's a regression introduced in the latest Raspbian kernel which breaks Bluetooth for the controllers. @psyke83 posted a script to downgrade the kernel and the accompanying packages, look in his post history and you'll find it.
        4 1 Reply Last reply Reply Quote 2
        • 4
          4uvak91 @mitu
          @mitu Thank you for a quick reply. Yeah, I was guessing this also.
          • 4
            4uvak91
            https://retropie.org.uk/forum/topic/22312/latest-update-and-ps3-sixaxis-controller/7
            Here is the link for others. Will test later.
            E: Downgrading worked.
