    Need help installing OpenRCT2
    portsopenrct2
    27 Posts 2 Posters 2.5k Views
      retropi19
      you need to install this packages: sudo apt-get install make cmake
      Rpi3B+ USB 2.0 Boot HDD Hitachi 40GB 5400rpm
      Rpi4 4GB rev1.4 USB 3.0 Boot HDD Hitachi 160GB 7200rpm
      • quicksilverQ
        quicksilver @retropi19
        @retropi19 I believe I already did that as it required cmake with the older version of OpenRCT2 as well
          retropi19 @quicksilver
          @quicksilver check it check also if you installed all the dependencies
          • quicksilverQ
            @retropi19 according to the documentation I installed all the correct dependencies
              retropi19
              Did you delete the folder you compiled before the older version or you compiled on it the latest one? if not delete totally the folder and try the latest version
              otherwise maybe the latest version is the problem try the 0.2.1 version and if it does the same try the 0.2.0
              to create a shortcut do this
              cd /home/pi/RetroPie/roms/ports
              sudo nano Openrct2.sh
              inside type the game location eg: cd /home/pi/openrct2 press enter to go a line under
              and type the command that you start the game
              finally press control+x and yes to save
              • quicksilverQ
                @retropi19 Alright so I found part of the problem. The newer version of OpenRCT2 requires cmake 3.9 or higher and the cmake included in the repository is only 3.7.2. Any idea on how to install a more updated version of cmake?
                EDIT:
                So I was able to update to a newer version of cmake but the OpenRCT2 build now fails. Here is a copy of the CMake error log
                Performing C++ SOURCE FILE Test CXX_WARN_MISSING_VARIABLE_DECLARATIONS failed with the following output:
                Change Dir: /home/pi/OpenRCT2-0.2.2/build/CMakeFiles/CMakeTmp
                Run Build Command:"/usr/bin/make" "cmTC_380c5/fast"
                /usr/bin/make -f CMakeFiles/cmTC_380c5.dir/build.make CMakeFiles/cmTC_380c5.dir/build
                make[1]: Entering directory '/home/pi/OpenRCT2-0.2.2/build/CMakeFiles/CMakeTmp'
                Building CXX object CMakeFiles/cmTC_380c5.dir/src.cxx.o
                /usr/bin/c++    -Ofast -DNDEBUG -mcpu=cortex-a53 -DCXX_WARN_MISSING_VARIABLE_DECLARATIONS   -Wmissing-variable-declarations -std=gnu++1z -o CMakeFiles/cmTC_380c5.dir/src.cxx.o -c /home/pi/OpenRCT2-0.2.2/build/CMakeFiles/CMakeTmp/src.cxx
                c++: error: unrecognized command line option '-Wmissing-variable-declarations'; did you mean '-Wmissing-declarations'?
                CMakeFiles/cmTC_380c5.dir/build.make:65: recipe for target 'CMakeFiles/cmTC_380c5.dir/src.cxx.o' failed
                make[1]: *** [CMakeFiles/cmTC_380c5.dir/src.cxx.o] Error 1
                make[1]: Leaving directory '/home/pi/OpenRCT2-0.2.2/build/CMakeFiles/CMakeTmp'
                Makefile:126: recipe for target 'cmTC_380c5/fast' failed
                make: *** [cmTC_380c5/fast] Error 2
                Source file was:
                int main() { return 0; }
                Performing C++ SOURCE FILE Test CXX_WARN_DUPLICATED_BRANCHES failed with the following output:
                Run Build Command:"/usr/bin/make" "cmTC_a4d47/fast"
                /usr/bin/make -f CMakeFiles/cmTC_a4d47.dir/build.make CMakeFiles/cmTC_a4d47.dir/build
                Building CXX object CMakeFiles/cmTC_a4d47.dir/src.cxx.o
                /usr/bin/c++    -Ofast -DNDEBUG -mcpu=cortex-a53 -DCXX_WARN_DUPLICATED_BRANCHES   -Wduplicated-branches -std=gnu++1z -o CMakeFiles/cmTC_a4d47.dir/src.cxx.o -c /home/pi/OpenRCT2-0.2.2/build/CMakeFiles/CMakeTmp/src.cxx
                c++: error: unrecognized command line option '-Wduplicated-branches'; did you mean '-Wduplicated-cond'?
                CMakeFiles/cmTC_a4d47.dir/build.make:65: recipe for target 'CMakeFiles/cmTC_a4d47.dir/src.cxx.o' failed
                make[1]: *** [CMakeFiles/cmTC_a4d47.dir/src.cxx.o] Error 1
                Makefile:126: recipe for target 'cmTC_a4d47/fast' failed
                make: *** [cmTC_a4d47/fast] Error 2
                Source file was:
                Performing C++ SOURCE FILE Test CXX_WARN_RESTRICT failed with the following output:
                Run Build Command:"/usr/bin/make" "cmTC_9be04/fast"
                /usr/bin/make -f CMakeFiles/cmTC_9be04.dir/build.make CMakeFiles/cmTC_9be04.dir/build
                Building CXX object CMakeFiles/cmTC_9be04.dir/src.cxx.o
                /usr/bin/c++    -Ofast -DNDEBUG -mcpu=cortex-a53 -DCXX_WARN_RESTRICT   -Wrestrict -std=gnu++1z -o CMakeFiles/cmTC_9be04.dir/src.cxx.o -c /home/pi/OpenRCT2-0.2.2/build/CMakeFiles/CMakeTmp/src.cxx
                c++: error: unrecognized command line option '-Wrestrict'; did you mean '-mrestrict-it'?
                CMakeFiles/cmTC_9be04.dir/build.make:65: recipe for target 'CMakeFiles/cmTC_9be04.dir/src.cxx.o' failed
                make[1]: *** [CMakeFiles/cmTC_9be04.dir/src.cxx.o] Error 1
                Makefile:126: recipe for target 'cmTC_9be04/fast' failed
                make: *** [cmTC_9be04/fast] Error 2
                Source file was:
                Performing C++ SOURCE FILE Test CXX_WARN_UNREACHABLE_CODE_BREAK failed with the following output:
                Run Build Command:"/usr/bin/make" "cmTC_39e2b/fast"
                /usr/bin/make -f CMakeFiles/cmTC_39e2b.dir/build.make CMakeFiles/cmTC_39e2b.dir/build
                Building CXX object CMakeFiles/cmTC_39e2b.dir/src.cxx.o
                /usr/bin/c++    -Ofast -DNDEBUG -mcpu=cortex-a53 -DCXX_WARN_UNREACHABLE_CODE_BREAK   -Wunreachable-code-break -std=gnu++1z -o CMakeFiles/cmTC_39e2b.dir/src.cxx.o -c /home/pi/OpenRCT2-0.2.2/build/CMakeFiles/CMakeTmp/src.cxx
                c++: error: unrecognized command line option '-Wunreachable-code-break'; did you mean '-Wunreachable-code'?
                CMakeFiles/cmTC_39e2b.dir/build.make:65: recipe for target 'CMakeFiles/cmTC_39e2b.dir/src.cxx.o' failed
                make[1]: *** [CMakeFiles/cmTC_39e2b.dir/src.cxx.o] Error 1
                Makefile:126: recipe for target 'cmTC_39e2b/fast' failed
                make: *** [cmTC_39e2b/fast] Error 2
                Source file was:
                Performing C++ SOURCE FILE Test CXX_WARN_RANGE_LOOP_ANALYSIS failed with the following output:
                Run Build Command:"/usr/bin/make" "cmTC_1a910/fast"
                /usr/bin/make -f CMakeFiles/cmTC_1a910.dir/build.make CMakeFiles/cmTC_1a910.dir/build
                Building CXX object CMakeFiles/cmTC_1a910.dir/src.cxx.o
                /usr/bin/c++    -Ofast -DNDEBUG -mcpu=cortex-a53 -DCXX_WARN_RANGE_LOOP_ANALYSIS   -Wrange-loop-analysis -std=gnu++1z -o CMakeFiles/cmTC_1a910.dir/src.cxx.o -c /home/pi/OpenRCT2-0.2.2/build/CMakeFiles/CMakeTmp/src.cxx
                c++: error: unrecognized command line option '-Wrange-loop-analysis'
                CMakeFiles/cmTC_1a910.dir/build.make:65: recipe for target 'CMakeFiles/cmTC_1a910.dir/src.cxx.o' failed
                make[1]: *** [CMakeFiles/cmTC_1a910.dir/src.cxx.o] Error 1
                Makefile:126: recipe for target 'cmTC_1a910/fast' failed
                make: *** [cmTC_1a910/fast] Error 2
                Source file was:
                Performing C++ SOURCE FILE Test CXX_WARN_TAUTOLOGICAL_ZERO_COMPARE failed with the following output:
                Run Build Command:"/usr/bin/make" "cmTC_b9376/fast"
                /usr/bin/make -f CMakeFiles/cmTC_b9376.dir/build.make CMakeFiles/cmTC_b9376.dir/build
                Building CXX object CMakeFiles/cmTC_b9376.dir/src.cxx.o
                /usr/bin/c++    -Ofast -DNDEBUG -mcpu=cortex-a53 -DCXX_WARN_TAUTOLOGICAL_ZERO_COMPARE   -Wtautological-unsigned-zero-compare -std=gnu++1z -o CMakeFiles/cmTC_b9376.dir/src.cxx.o -c /home/pi/OpenRCT2-0.2.2/build/CMakeFiles/CMakeTmp/src.cxx
                c++: error: unrecognized command line option '-Wtautological-unsigned-zero-compare'; did you mean '-Wtautological-compare'?
                CMakeFiles/cmTC_b9376.dir/build.make:65: recipe for target 'CMakeFiles/cmTC_b9376.dir/src.cxx.o' failed
                make[1]: *** [CMakeFiles/cmTC_b9376.dir/src.cxx.o] Error 1
                Makefile:126: recipe for target 'cmTC_b9376/fast' failed
                make: *** [cmTC_b9376/fast] Error 2
                Source file was:
                Determining if the pthread_create exist failed with the following output:
                Run Build Command:"/usr/bin/make" "cmTC_7f22d/fast"
                /usr/bin/make -f CMakeFiles/cmTC_7f22d.dir/build.make CMakeFiles/cmTC_7f22d.dir/build
                Building CXX object CMakeFiles/cmTC_7f22d.dir/CheckSymbolExists.cxx.o
                /usr/bin/c++    -Ofast -DNDEBUG -mcpu=cortex-a53 -Wno-clobbered -fstrict-overflow -fstrict-aliasing -Werror -Wundef -Wmissing-declarations -Winit-self -Wall -Wextra -Wshadow -Wno-unknown-pragmas -Wno-missing-braces -Wno-comment -Wnonnull -Wno-unused-parameter -DDEBUG=0  -fPIE   -std=gnu++1z -o CMakeFiles/cmTC_7f22d.dir/CheckSymbolExists.cxx.o -c /home/pi/OpenRCT2-0.2.2/build/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx
                Linking CXX executable cmTC_7f22d
                /usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_7f22d.dir/link.txt --verbose=1
                /usr/bin/c++  -Ofast -DNDEBUG -mcpu=cortex-a53 -Wno-clobbered -fstrict-overflow -fstrict-aliasing -Werror -Wundef -Wmissing-declarations -Winit-self -Wall -Wextra -Wshadow -Wno-unknown-pragmas -Wno-missing-braces -Wno-comment -Wnonnull -Wno-unused-parameter -DDEBUG=0     CMakeFiles/cmTC_7f22d.dir/CheckSymbolExists.cxx.o  -o cmTC_7f22d
                CMakeFiles/cmTC_7f22d.dir/CheckSymbolExists.cxx.o: In function `main':
                CheckSymbolExists.cxx:(.text.startup+0x1c): undefined reference to `pthread_create'
                collect2: error: ld returned 1 exit status
                CMakeFiles/cmTC_7f22d.dir/build.make:97: recipe for target 'cmTC_7f22d' failed
                make[1]: *** [cmTC_7f22d] Error 1
                Makefile:126: recipe for target 'cmTC_7f22d/fast' failed
                make: *** [cmTC_7f22d/fast] Error 2
                File /home/pi/OpenRCT2-0.2.2/build/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx:
                #include <pthread.h>
                int main(int argc, char** argv)
                  (void)argv;
                #ifndef pthread_create
                  return ((int*)(&pthread_create))[argc];
                #else
                  (void)argc;
                  return 0;
                #endif
                  retropi19
                  or you post this on the github page of the port maybe they can help you more or you try to install an older version as i said before eg: 0.2.1 or 0.2.0
