    Retro PIE Control Block not working
    control block
    2 Posts 2 Posters 528 Views
      kaneo123
      Install the github using this command wget -O - https://raw.githubusercontent.com/petrockblog/ControlBlockService2/master/install.sh | sudo bash
      And after it turns device screen off but keeps raspberry running, when it tries to turn back on it does the same. if i remove the control block. It loads with no issue :/
      Am i missing something here? Do ineed to install a operating system first? I am very confused.
        petrockblog Global Moderator
        Sounds as if something is going very wrong. Can you post a picture of your hardware setup here?
