    Audio not working, restart system will correct it
    audio outputaudio issuesdigit to analog
    5 Posts 3 Posters 726 Views
      beezerhale
      RetroPie Version Used - 4.4
      Retroarch 1.7.1
      ES v2.7.5rp
      Built From: Retropie from the retropie site
      Power Supply used: https://www.amazon.com/gp/product/B00L88M8TE/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
      USB Devices connected: joystick and 6 button (Gamelec 2 player setup)
      Here's the issue: every so often the audio will not work at all. No sound on video previews or in game. A restart normally corrects it. I've read issues others have had, but most foxes seem to be for issues of no audio at all. I can get audio, just need to restart. Any ideas on what I need to do?
      I have the Pi connected to the tv via hdmi, but have the audio coming from external speakers which are connected to using a Digital to Analog Audio Converter with Digital Optical Toslink and S/pdif Coaxial Inputs and Analog RCA and AUX 3.5mm (Headphone) Outputs - found here: https://www.amazon.com/gp/product/B00NJCCAKY/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
      and yes, I swapped the hdmi cable to make sure that wasn't the issue.
      Thank you for any help!
        edmaul69 @beezerhale
        @beezerhale in the retropie menu in audio settings did you try changing the audio from auto to hdmi? Also in the /boot/config.txt did you remove the # in front of the line
        #hdmi_drive=2
        To make it
        hdmi_drive=2
          beezerhale
          I did change it to hdmi and then I only get audio from the tv, not the external speakers. I need it from the external speakers.
          I will try changing the txt and report back here. Would that be needed considering the audio is going through the optical adapter and not the hdmi? Thank you!
            mitu Global Moderator @beezerhale
            @beezerhale Use the Audio menu in RetroPie and switch the output to the 3.5'' jack instead of HDMI or Auto.
              beezerhale @mitu
              @mitu Thank you. I sorted it. I changed the TV itself to "external speaker" only and the Pi to hdmi. It seems to work fine now. I get no audio at all when I choose "3.5" or "auto".
