    FB NEO and bezel project
    bezel project fneo
    5 Posts 2 Posters 2.2k Views
    • L
      lenny
      Hello all, I just updated my retropie on linux mint 19 and now have fbneo which works great. My question is my bezels no longer work for the fbneo core only, is there a way to get them working again? I tried renaming the config folder for the bezel configs but no luck. Thanks
        mitu Global Moderator @lenny
        @lenny I think renaming would be the way to go - what folder did you rename and what's the new name you've given ?
        • L
          lenny
          @mitu I tried renaming the FB Alpha folder in opt/retropie/configs/all/retroarch/config to FB Neo with no luck. Thanks
            @lenny I think the core name is FinalBurn Neo now, try renaming the old FBAlpha folder like this and see if it works.
            • L
              lenny
              @mitu Thank You! It works!
