    Drastic on pi 3 1.2 not booting roms
    drasticroms wont loadpi 3 b
    27 Posts 4 Posters 5.0k Views
      joe.info
      I have Pinn lite and emulation station installed so that my pi switches from LCD to hdmi on boot. I installed drastic from the experimental packages menu. It won't load any roms at all. Is there a diagnostic I can run or do you guys know where I should start to get it running? I tried updating, and reinstalling but no luck.
        mitu Global Moderator @joe.info
        @joe-info What version of Raspbian are you running ? Drastic needs to be patched in order to work with recent versions of Raspbian due to some system library changes.
        Post the log file (/dev/shm/runcommand.log), taken after you launch a NDS ROM.
        J 3 Replies Last reply Reply Quote 0
          joe.info @mitu
          @mitu I believe I am on 4.4 as per the retro pie setup menu. I'll get that log file posted in just a sec.
            joe.info @mitu
            @mitu oddly enough, trying to launch a game via drastic seems to mess up the runcommand screen opening up.
              joe.info @joe.info
              @joe-info yup. No runcommand. Drastic breaks it. Is there another way to get the error log or should I just patch drastic? How do I patch drastic? Lol
                joe.info @mitu
                Log started at: Tue 18 Jun 00:58:39 UTC 2019
                RetroPie-Setup version: 4.4 (cda9ffcb)
                System: Linux retropie 4.19.42-v7+ #1219 SMP Tue May 14 21:20:58 BST 2019 armv7l GNU/Linux
                Installing 'drastic' : NDS emu - DraStic
                drastic_rpi/game_database.xml
                drastic_rpi/drastic_readme.txt
                drastic_rpi/drastic
                drastic_rpi/system/
                drastic_rpi/system/drastic_bios_arm7.bin
                drastic_rpi/system/drastic_bios_arm9.bin
                drastic_rpi/usrcheat.dat
                drastic_rpi/drastic_logo_1.raw
                drastic_rpi/drastic_logo_0.raw
                Applying vendor graphics patch: /opt/retropie/emulators/drastic/drastic
                /opt/retropie/emulators/drastic /home/pi
                Configuring 'drastic' : NDS emu - DraStic
                '/opt/retropie/configs/nds/drastic/game_database.xml' -> '/opt/retropie/emulators/drastic/game_database.xml'
                '/opt/retropie/configs/nds/drastic/system/drastic_bios_arm7.bin' -> '/opt/retropie/emulators/drastic/system/drastic_bios_arm7.bin'
                '/opt/retropie/configs/nds/drastic/system/drastic_bios_arm9.bin' -> '/opt/retropie/emulators/drastic/system/drastic_bios_arm9.bin'
                '/opt/retropie/configs/nds/drastic/usrcheat.dat' -> '/opt/retropie/emulators/drastic/usrcheat.dat'
                '/opt/retropie/configs/nds/drastic/drastic_logo_0.raw' -> '/opt/retropie/emulators/drastic/drastic_logo_0.raw'
                '/opt/retropie/configs/nds/drastic/drastic_logo_1.raw' -> '/opt/retropie/emulators/drastic/drastic_logo_1.raw'
                /home/pi
                Log ended at: Tue 18 Jun 00:58:52 UTC 2019
                Total running time: 0 hours, 0 mins, 13 secs
                • EfriimE
                  Efriim @joe.info
                  @joe-info
                  Hey joe, drastic comes with a pair of bios that can load some unencrypted roms. What you need is the actual arm9 and arm7 bios from an nds.
                  They go in the folder \configs\nds\drastic\system\
                  nds_bios_arm7.bin
                  nds_bios_arm9.bin
                    @joe-info the binary is patched, according to your log, so this is not the problem. Maybe Drastic doesn't like your resolution ?
                      joe.info @mitu
                      @mitu I am using the 7 in pi touchscreen on my set up but im not sure how to add photos, from my phone, here so you can see.
                        joe.info @joe.info
                          joe.info @Efriim
                          @Efriim I'll try this as soon as I get off work. Thank you for the suggestion.
                            joe.info @mitu
                            @mitu thank you so much for your help with this.
                              joe.info @Efriim
                              @Efriim do I delete the other drastic_bios?
                              • EfriimE
                                Efriim @joe.info
                                @joe-info
                                There is no need to, the nds_bios will be used if it is available.
                                  joe.info @Efriim
                                  @Efriim I added the official bios but i get the same result. It just loops back to the game selection list and it breaks any run command features like rasping config or the command line interface.
                                  EfriimE 3 Replies Last reply Reply Quote 0
                                  • EfriimE
                                    Efriim @joe.info
                                    @joe-info
                                    I guess that the RetroPie Setup needs to be updated to get the most recent version of DraStic.
                                    Enter the RetroPie-Setup Script menu.
                                    retropie_setup >> Update RetroPie-Setup script
                                    retropie_setup >> Manage packages > experimental > drastic > install from binary
                                    • EfriimE
                                      Efriim @joe.info
                                      @joe-info
                                      I tried drastic, it does seem to break the run-command menu. You can catch it the first time, but then it won't work after exiting drastic. The menu is still there, it is just in the background and you cant see it (needs a failsafe exit shortcut/key).
                                      For the emulator, 640x480 resolution doesn't quite work, there was no drastic-GUI available in this res mode. 480p and 720p were okay though.
                                      J quicksilverQ 2 Replies Last reply Reply Quote 0
                                      • EfriimE
                                        Efriim @joe.info
                                        @joe-info
                                        Sorry that it isn't working, maybe @mitu will know what to do with the script module or launch item.
                                          joe.info @Efriim
                                          @Efriim how do I change the resolution for drastic to one that works? Maybe if I get everything else right, then I can run the error log again to see what's up.
                                          • EfriimE
                                            Efriim @joe.info
                                            @joe-info
                                            The run-command should work for one time if you reboot.
