    GPI case issues
    gpi
    4 Posts 4 Posters 1.7k Views
    • W
      wkelley89
      Installed retropi and the safe shut down script.
      Now the pi will only boot sometimes.
      It get stuck in the checking disk screen or it says the account is locked. Can someone help.
        spud11
        There's quite a detailed guide here how to setup the GPI with Retropie. I'm waiting for my GPI to arrive but was planning to use this guide as the initial basis for installing everything:
        https://howchoo.com/g/ndc3njbhytv/retroflag-gpi-setup#install-the-safe-shutdown-script
          mitu Global Moderator @wkelley89
          @wkelley89 update the OS and packages, also the Retropie setup acript, this should solve this issues. Ideally before putting the Pi in the case.
          • ByteThisB
            ByteThis
            @wkelley89 There is a dedicated reddit sub for the GPI case. Other people have had the same issue : https://www.reddit.com/r/retroflag_gpi/
