    USB HUB not detecting Joysticks
    hubjoystick4 player
    5 Posts 2 Posters 596 Views
      TheBlueBanner
      For a Raspberry Pi 3: I have seen issues other people have had with USB hubs, but my issue is that when plugged into the hub, the gamepads are not even detected. I have tried having the hub powered and not powered, but neither work. My buttons light up when plugged into the hub, but as stated before, the gamepads are not detected. FYI, I have tested plugging the gamepads directly into the pi, and they work fine. Thanks
        edmaul69 @TheBlueBanner
        @TheBlueBanner is it a usb 3.0 hub? There are quite a few 3.0 hubs that the pi doesnt play nice with.
          TheBlueBanner
          Yes. I am using this https://www.amazon.com/gp/product/B00DQFGH80/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1. What hub would you suggest? Thanks.
            TheBlueBanner
            I just ended buying this. https://thepihut.com/products/4-port-usb-hub-usb-2-0. Once I have it, I will update this post.
              TheBlueBanner
              @TheBlueBanner said in USB HUB not detecting Joysticks:
              So, I received this USB hub. It worked! The only issue I have is that there doesn't seem to be enough power going to the LED lights, and they are dimmer than what I would like. I am not sure if there is anything I can do, but it worked none the less.
