    Need help Retropie doesnt boot after shutdown
    help retropieno console errboot error
    1 Posts 1 Posters 397 Views
      Shaz
      Hi guys i need your help so here is the prblem with my specs and how to replicate it ( I think)
      Power Supply used: CanaKit 2.5A Micro USB Power Supply
      RetroPie Version Used: Version 4.4
      Built From: Pre made SD Image on RetroPie Website
      USB Devices connected: Hp Keyboard
      Controller used: Snes USB Controller
      Error messages received: None unless the fact that i can’t boot retro pie after shutdown.
      Guide used: The official Retropie Installation Guide
      Attachment of config files:
      How to replicate the problem: I bought the Retropie SNES gaming kit and I downloaded the Pre made SD Image from the official retropie.org.uk website and i used 7.zip to extract the files and then flashed the file via Win32DiskImager and on the first boot it worked flawlessly but after the shutdown and removing the power supply. I wanted to boot the raspberry pi again so I could transfer ROMs via a USB Drive but it couldn’t boot I saw an irregular blinking pattern and I used Google to find out what that pattern meant. So according to the info it meant that I have no SD Card activity. So I formatted the SD Card via SD Card Formatter and tried the whole process again without positive results. I also tried to add the commands
      hdmi_force_hotplug=1
      hdmi_drive=2 .
      I don’t know what to do but I for sure know that the Image can’t be corrupted. And then I thought that you guys might have a solution for my problem.
