    Retroflag GPi Vice resolution problem
    vice
    3 Posts 3 Posters 718 Views
      pumpytums
      Hi everyone,
      I managed to get hold of a Retroflag GPi, its a great case for the zero. I recently installed Vice and it boots but the screen seems magnified I can only see a corner of the C64 screen and part of the menu. The GPi's screen is set at 320 x 240 does anyone have any ideas on how to change Vice so it displays correctly please?
      So far everything else works fine so its only Vice.
      Thanks in advance
        Please add more info about your system - https://retropie.org.uk/forum/topic/3/read-this-first.
        • ds17fD
          ds17f
          The setting you're looking for is:
          Settings -> Video Settings -> VICII border mode: None.
