    Problems with PSX Controller Configuration
    psx controllercontrol configpsx
    4 Posts 3 Posters 711 Views
      bieelff
      Hey, first of all, I'm sorry for my weak English.
      I will report my problem quickly.
      This is the first time I install the retropie and try to configure it. I got perfect working with the SNES and NEO-GEO emulators.
      But with the PSX emulator only a few buttons of my control work, such as directional, analog and the X button (psx button), all other buttons do not work, this in all games I tested (Crash 2, for example). I performed the configuration of the control for the first time and in several frustrated attempts I tried to configure using Hotkey + Y> controls or settings> input
      Why does not the start, square, triangle, circle button work and only the directives and X work?
      I am using a generic usb control of Playstation 2.
      thx.
      mituM edmaul69E 2 Replies Last reply Reply Quote 0
        mitu Global Moderator @bieelff
        @bieelff Which emulator are you using for PS1 games - pcsx_rearmed or lr-pcsx_rearmed ? Can you try re-configuring the controller, during the configuration skip the Hotkey assignment and then accept the 'Use Select as Hotkey' settings ?
          edmaul69 @bieelff
          @bieelff also set the face buttons up like a snes controller and not an xbox controller. Then you dont have to remap them in the emulators.
            bieelff
            After spending the weekend thinking about which procedure was done wrong, I remembered that I performed many installations and updates hoping to fix the problem, so I downloaded a clean .img and installed it again. After reinstalling the OS the control worked correctly, thank you anyway.
