    overscan_ NOT WORK AFTER UPDATE! 4.5 in EmulationStation.
    4.5updateoverscan
    33 Posts 5 Posters 5.0k Views
      SergioPoverony
      RetroPie 4.5
      Linux 4.19.50-v7+ armv7l GNU/Linux
      HDMI 3.5 screen
      overscan_left, right etc not work after update in EmulationStation. I see boot log and see - overscan fork fine. After load ES - Overscan not work
      In ES you can see more space to right. Ovescan not work. After i move to RetroPie setup. My overscan work correctly. I special make more for view.
        mitu Global Moderator @SergioPoverony
        @SergioPoverony Can you post your /boot/config.txt with the overscan settings ?
          SergioPoverony @mitu
          disable_overscan=1
          overscan_left=40
          overscan_right=-36
          overscan_top=-48
          overscan_bottom=0
          sdtv_mode=2
          dtparam=i2c_arm=on
          dtparam=spi=off
          dtparam=audio=on
          gpu_mem_256=128
          gpu_mem_512=256
          gpu_mem_1024=256
          overscan_scale=1
          dtoverlay=dwc2
          hdmi_force_hotplug=1
          hdmi_drive=1
          hdmi_group=2
          hdmi_mode=12
          gpu_mem=128
            You have both disable_overscan=1 and overscan_... settings together. Can you try commenting the former and reboot after modifying the file ? Add a # on the line with disable_overscan so it reads:
            #disable_overscan=1
            and see if it makes a difference.
              ok. thank you. Whay this work fine in old version?
                @SergioPoverony I don't really understand your latest reply.
                  Why does my config work well in the previous version? I do not understand too.
                    @SergioPoverony Is it working now after you modified it ? It's probably a change in the kernel/firmware for the Raspberry PI.
                    EDIT:this might be the cause of the default overscan behavior change.
                      Thank you
                        i do as you tell
                        #disable_overscan=1
                        and overscan_left right and etc work only in boot or retropi-setup... in EmulationStation him not work
                        mituM saccublendaS 2 Replies Last reply Reply Quote 0
                          @SergioPoverony said in overscan_ NOT WORK AFTER UPDATE! 4.5 in EmulationStation.:
                          Thats should be handled by overscan_scale=1 - do you still have that line in your config.txt file ?
                            @mitu said in overscan_ NOT WORK AFTER UPDATE! 4.5 in EmulationStation.:
                            I make downgrade. Me need update again. After him i check all again.
                            • saccublendaS
                              saccublenda @SergioPoverony
                              @SergioPoverony I've noticed the same issue. After upgrading to 4.5 overscan settings apply differently to ES and console (including splashscreen).
                              disable_overscan is commented and overscan_scale is set to 1.
                                mitu Global Moderator @saccublenda
                                @saccublenda I'd love so get more info about your setup - are you also using a LCD screen or just a TV (HDMI) ? Does removing overscan_scale makes a difference ?
                                saccublendaS 1 Reply Last reply Reply Quote 0
                                • saccublendaS
                                  saccublenda @mitu
                                  @mitu TV with HDMI.
                                  With overscan_scale=1 ES fits the screen correctly, but console has black borders.
                                  Without overscan_scale=1 console fits the screen correctly, but ES goes off screen.
                                    @saccublenda said in overscan_ NOT WORK AFTER UPDATE! 4.5 in EmulationStation.:
                                    Can you run fbset to see what's the screen size of the console and compare it to the TV's resolution ?
                                    You can try adding disable_overscan=1 to remove any overscan borders altogether.
                                      SergioPoverony
                                      Can you run
                                      Cant work
                                      Fbset 800*600
                                      #disable_overscan=1
                                      overscan_left=80
                                      overscan_right=42
                                      overscan_top=46
                                      overscan_bottom=46
                                      dtparam=i2c_arm=on
                                      dtparam=spi=off
                                      dtparam=audio=on
                                      gpu_mem_256=128
                                      gpu_mem_512=256
                                      gpu_mem_1024=256
                                      overscan_scale=1
                                      dtoverlay=dwc2
                                      hdmi_drive=1
                                      hdmi_group=2
                                      hdmi_mode=12
                                      gpu_mem=128
                                      HDMI connection to scrren
                                      Overscan work only console/terminal mode and not work in EmulationStation
                                      • saccublendaS
                                        saccublenda @mitu
                                        With disable_overscan=1 I get from fbset
                                        mode "1920x1080"
                                            geometry 1920 1080 1920 1080 32
                                            timings 0 0 0 0 0 0 0
                                            rgba 8/16,8/8,8/0,8/24
                                        endmode
                                        With this configuration the console fits the screen and ES goes off screen.
                                        With #disable_overscan=1 and
                                        overscan_left=10
                                        overscan_right=10
                                        overscan_top=10
                                        overscan_bottom=10
                                        I get from fbset
                                        mode "1804x964"
                                            geometry 1804 964 1804 964 32
                                        endmode
                                        With this configuration both console and ES have black borders, but the console has significantly larger borders than ES.
                                          SergioPoverony @saccublenda
                                          @saccublenda
                                          #disable_overscan=1
                                          overscan_left=10
                                          overscan_right=10
                                          overscan_top=10
                                          overscan_bottom=10
                                          mode "800x600"
                                              geometry 800 600 800 600 32
                                          endmode
                                          and
                                          disable_overscan=1
                                          #overscan_left=10
                                          #overscan_right=10
                                          #overscan_top=10
                                          #overscan_bottom=10
                                          mode "800x600"
                                          endmode
                                          I tell NOT WORK tested Pi3A+ and Zero W
                                          Any edit work ONLY TERMINAL/CONSOLE and not work in ES
                                          • matchamanM
                                            matchaman
                                            I can confirm this, the exact same settings on 4.4 vs 4.5.
