    bash command for this code need help
    bash commandscript
    4 Posts 2 Posters 391 Views
      kok00
      Folder location /home/pi/RetroPie/roms
      contains
      streetf1.zip
      ssfx2.zip
      turbo2.zip
      mgaman.zip
      shnobi.zip
      tkken.zip
      donkey.zip
      suprman.zip
      Folder location /opt/retropie/configs/all/emulationstation/downloaded_images/
      contains files
      streetf1.zip
      Scan and compare both locations path and if the .zip has missing images then move the .zip files to new created folder in same path.
      #!/bin/bash
         file1="/home/pi/RetroPie/roms"
         file2="/opt/retropie/configs/all/emulationstation/downloaded_images/"
             if cmp -s "$file1" "$file2"; then
                 printf 'The file "%s" is the same as "%s"\n' "$file1" "$file2"
         #if title.zip and image.jpg title matches then ignore it
             else
                 printf 'The file "%s" is different from "%s"\n' "$file1" "$file2"
         #if title.zip and image title not match then create a folder and move all .zip files with missing images.
             fi
      this path /home/pi/RetroPie/roms contains alot of .zip so i need something to loop through both path and do the work.
        cyperghost @kok00
        @kok00 hmmm you compare a zipped rom file with a image file. Very interesting ...
        You know this won't work.
        This would be better
        https://github.com/meleu/share/blob/master/images-cleaner.sh
          kok00
          it will work only compare the title and not extension?
            cyperghost @kok00
            @kok00 cmp does not care of file names, it compares content
