    python script to remove roms for no artwork not working.
    scriptsromsremove
    2 Posts 2 Posters 467 Views
      kok00
      Downloaded this https://github.com/andywarburton/RetroPie-Tools
      and now i endeavored modifying some paths but for some reason i get
      TEST COMPLETE: 0 of 0 total (0 remain)
      Only want to test with mame-libretro and removed other emulators.
      i placed the script in root and run it.
      i then selected the test option and its not working even others gives same results,the clean option creates a folder but nothing else.
      # This program is intended to remove any roms from RetroPie that do not
      # have any artwork. It will work on a Raspberry Pi or a Linux computer
      import os
      import os.path
      import sys
      import string
      # config vars, if you are using non-standard stuff change these
      # os.environ['HOME'] pulls the users current home directory, wherever
      # that is, and changes with the username
      # /opt/ does not need to change as this is standard across RetroPie and
      # linux distros
      rom_dir         = os.environ['HOME'] + '/home/pi/RetroPie/roms'
      bak_dir         = os.environ['HOME'] + '/home/pi/RetroPie/cleaned_up'
      img_dir         = '/opt/retropie/configs/all/emulationstation/downloaded_media'
      allowed_systems = [
                        'mame-libretro'
      # The number of deleted roms
      delete_count    = 0
      # The total number of roms
      total_count     = 0
      question = """
            WARNING! THIS SCRIPT WILL PERMANENTLY DELETE FILES!
              ===== PLEASE BACKUP BEFORE RUNNING THIS! =====
            ===== IT IS RECOMMENDED TO DO "TEST" FIRST! =====
            TYPE "TEST" TO DO A TEST RUN THAT WILL TELL YOU HOW
                MANY FILES WOULD BE CHANGED BY AN ACTUAL RUN
          TYPE "CLEAN" TO MOVE UNWANTED FILES TO A BACKUP DIRECTORY
                       (/home/pi/RetroPie/cleaned_up)
                    TYPE "DELETE" IF YOU ARE SOUND MIND,
                 UNDERSTAND THE RISKS, AND WISH TO PROCEED
      spacer = "*****************************************************************"
      # question.replace() replaces the output text's CLEAN directory (what is
      # presented to the user) with the actual directory
      user_input = raw_input(question.replace('/home/pi',os.environ['HOME'])).upper()
      # verify user input
      if user_input in ['DELETE','TEST','CLEAN']:
          # for the cleanup process, we need somewhere to put our backups
          if user_input == 'CLEAN':
              if not os.path.isdir(bak_dir):
                  os.makedirs(bak_dir)
          # for all the files and directories to said files in the rom directory
          for root, subdirs, files in os.walk(rom_dir):
              list_file_path = os.path.join(root, 'foo.txt')
              with open(list_file_path, 'wb') as list_file:
                  os.remove(list_file_path)
                  for filename in files:
                      file_path = os.path.join(root, filename)
                      rom_name = filename.split('.')[0]
                      system_name = file_path.split('/')[-2]
                      # verify system is allowed (do not want to mess with
                      # other folders in the roms directory)
                      if system_name in allowed_systems:
                          total_count += 1
                          image_path = img_dir + '/' + system_name + '/screenshots/' +\
                                          rom_name + '.png'
                          if not os.path.isfile(image_path):
                              ## no image found, we should delete the rom!
                              if user_input == 'DELETE':
                                  print "DELETING: " + system_name + "/" + rom_name +\
                                          " (" + filename + ")"
                                  os.remove(file_path)
                                  delete_count += 1
                              elif user_input == 'CLEAN':
                                  print "CLEANING: " + system_name + "/" + rom_name +\
                                  system_bak_dir = bak_dir + '/' + system_name
                                  bak_file_path = system_bak_dir + '/' + filename
                                  if not os.path.isdir(system_bak_dir):
                                      os.makedirs(system_bak_dir)
                                  os.rename(file_path, bak_file_path)
                                  delete_count += 1
                              else:
                                  print "TESTING: " + system_name + "/" + rom_name +\
                                  ## do nothing
                                  delete_count += 1
          remaining_roms = total_count - delete_count
          print "\n" + spacer
          print user_input + " COMPLETE: " + str(delete_count) + " of " +\
              str(total_count) + " total (" + str(remaining_roms) + " remain)"
          print spacer
      else:
          print "INPUT NOT RECOGNIZED, PLEASE TRY AGAIN"
          sys.exit()
      • herb_fargusH
        herb_fargus administrators @kok00
        @kok00 don't know anything about the script but for the record there are some non working parents that are required to make clones work so if you delete them they may break more games depending on the type of rom set you have.
