    Can’t get my I-PAC and arcade buttons to work
    ipac 2control configbuttonsjoysticks
    13 Posts 4 Posters 1.4k Views
    • L
      Lugzyboy82
      Hi guys
      I have installed my arcade buttons on my machine today and connected the cables etc. They are all connected to an I-PAC 2.
      I just don’t know where to start and how to get it to work as it came without any instructions.
      Any help, as ever, would be much appreciated.
        Pepper
        This going to be up to you. However you want your buttons to be set up a,b,x,y etc... when you launch emulationstation you will be prompted to set up control, when it asks you for button, select the button you want it mapped to
        • L
          Lugzyboy82 @Pepper
          @Pepper thanks for your reply. I have done this successfully. The only issue I have no is when you hold down or up on the joystick, it doesn’t scroll. So in game play you have to tap the joystick up or down to make your character move either than holding in the up or down position. Hope this makes sense.
            Pepper
            Sorry I can’t be of more help. I too have the iPac 2 and it worked for me right out of the box. Maybe someone else can chime in? Did you download retropie from this site?
              Pepper
              So if I understand. While playing a game you have to keep tapping right to continually move right?
              • L
                Lugzyboy82 @Pepper
                @Pepper that’s correct.
                • HalvhjearneH
                  Halvhjearne
                  sounds like you reversed the connection to the microswitches, and they will therefore only activate when you release?
                  idk how your microswitches on your joystick looks, but perhaps you can take a picture.
                  L 2 Replies Last reply Reply Quote 0
                  • L
                    Lugzyboy82 @Halvhjearne
                    @Halvhjearne I will try and get some pictures on here shortly
                    • L
                      @Halvhjearne my phone won’t let me upload pictures as they are too big. I have the power connector then 2 5 pin connectors next to each other. I have my wires connected to the first connection. Should I connect it to the second connection.
                      HalvhjearneH rbakerR 2 Replies Last reply Reply Quote 0
                      • HalvhjearneH
                        Halvhjearne @Lugzyboy82
                        @Lugzyboy82
                        i have no idea what you mean by that, the microswitches usually looks and is wired like this:
                        my thinking is that you may have connected the wrong leg, but you are talking about a 5pin connector?
                        edit:
                        have you read the instructions from ultimarc?
                        https://www.ultimarc.com/ipac2.html
                        • rbakerR
                          rbaker @Lugzyboy82
                          @Lugzyboy82 Have you read this:
                          https://retropie.org.uk/forum/topic/8987/guide-setting-up-a-retropie-controls-using-ipac2-controller-extensive-tutorial-preconfigured-files
                          or have you visited https://github.com/iberov/retropie_ipac2_setup_wiki ?
                          This extensive tutorial has all you need. However, if wired correctly as stated above, it will work out of the box with emulation station.
                          • L
                            Lugzyboy82
                            The micro switches seem to be fine as I tried the wires on the opposite joystick and still gave the same results. I spoke to the company I bought the joysticks off and they said it sounds like a ground issue.
                            I re wired the joystick on the other 5 pin terminal and re arranged the wiring on the iPac accordingly. Still does the same thing.
                            Is there a way of restoring the iPac to factory settings to start again??
                            • L
                              Lugzyboy82
                              I have managed to get it operating correctly. I just need to configure the buttons now. Thank you.
