    Help with Gamecon GPIO Input
    gamecongamecondriverretropad
    8 Posts 2 Posters 621 Views
    • MaMikeeM
      MaMikee
      Hi! I've built my own joystick yokes with switches for a track-driven (tank-like) game and would like to wire the switches directly to the RPIE 3 A+ GPIO pins.
      I've installed the gamecon_gpio_rpi module. This only really talks about different controllers from manufacturers, not home built stuff.
      Here is the "TAB" key layout from MAME2003 which should help.
      Thanks for any help you can offer. I'm using a Freescale KL25Z currently to translate the switches to USB keystrokes now. I'd also like to add a start game switch that automatically drops a coin first. I don't know what "RetroPad1" is, for example.
        mitu Global Moderator @MaMikee
        @MaMikee said in Help with Gamecon GPIO Input:
        The gamecon driver has a few operating schemas, including custom mappings - did you look at the documentation ?
        Since you're running with a Libretro Core (lr-mame2003 possibly), that's the RetroPad virtual input device, specific to RetroArch - see here for an explanation on what and how the RetroPad works.
        • MaMikeeM
          MaMikee
          I'm savvy with pinball but not so much with home video game stuff so thanks for your patience.
          I've read all the doc I could find. A lot seems to apply to the old 26 pin GPIO connector.
          I am using mame2003 for this.
          Since I installed the gamecon lib the machine has become unusable, presumably because some of the inputs are being triggered by noise. Not sure which inputs I'll have to add PU resistors to. Does anyone know if the library activates the built-in pullups? And which inputs are set to active?
          I'm learning about this stuff all the time and that is good.
            While the schematics are from the RPI1 era, the driver is supported for the newer 40 pin GPIOS.
            You can remove the driver if that's not working as you expected.
            What's your emulation target - arcade only or also other systems ? There's also mkarcadejoystick which has the same concept, but has a more general approach.
            MaMikeeM 1 Reply Last reply Reply Quote 0
            • MaMikeeM
              MaMikee @mitu
              @mitu said in Help with Gamecon GPIO Input:
              Since a tank interface is pretty unique the target will be just for this interface. RPIE 3 or later with a 4x3 screen
              Left forward
              Left back
              Right forward
              Right back
              Fire
              Start 1 player (with drop coin and pause if possible - make it simple for the user, freeplay)
                What's the game you're trying to run/emulate ? Tank controls are not so universally used, so I assume the emulator would let you re-map this controls directly - to actual inputs - or to a standard (virtual) RetroPad button/input.
                • MaMikeeM
                  MaMikee
                  Atari's 1980 "Battlezone" from the bzone2 ROMs
                    Take a look at
                    demonstrating how to map 2 4way joysticks to tank controls - including the Atari Battle zone. IMHO as long as you simulate 2 joysticks, you'll be able to map them in MAME to the tank controls.
