    Emulator sound issues
    sound problemssound stopped
    6 Posts 4 Posters 604 Views
      Gazmeister
      Hi all...on all my emulator games there is a sound issue with the sound stopping for a split second every 5 seconds or so. The music etc is never continuous...it doesn't affect anything, so very annoying...anyone have a possible solution please? Thanks
      • EfriimE
        Efriim @Gazmeister
        @Gazmeister
        Please update your post with more information, following the "read this first" guide.
        and possibly the hdmi tv-set.
          Gazmeister @Efriim
          @Efriim hi it's a build from Retrodroid, an odroid xu4, running retropie and emulation station, the TV is a samsung ks8000, I'm new to retropie.thanks
          • Thorr69T
            Thorr69
            So, I am hearing 1) Not a raspberry pi and 2) a third party image. Both of those are not supported here.
            RPi 3b
            Official PSU
            Official RetroPie image
            Pandora's Box 5 controller
            simpleethatS 1 Reply Last reply Reply Quote 0
            • simpleethatS
              simpleethat @Thorr69
              While not Raspberry Pi is supported (there are numerous x86 topics here) third party images are not ever supported here. You should reach out to Retrodroid with your problem they know how it was configured and should be able to help you.
              • EfriimE
                Efriim @Gazmeister
                @Gazmeister said in Emulator sound issues:
                Thats tough, I don't notice a lot of XU4 users here, and I don't know anything about them. XU4 forum is a better idea.
                Perhaps updating the kernel, to the latest.
                Is there any sort of config.txt for the kernel options, like as on the raspberry pi? Usually for overclock, or hdmi configuration, also kernel overlays modules.
                there is a uboot.ini for XU4, and I didn't look far into it, there may be some configuration here that simply works
                How long of an hdmi cable just out of absurdity? I think a very long 50ft hdmi could have problems like that. TVs okay probably, but maybe there is 4k upscaling(?) interference, switch it to a "Game" or "Graphic" mode if you already haven't. Maybe disable 4k options if possible.
