    N64 Controller mappings not working with RetroPie 4.4
    n64 emulatornintendo 64retropie 4.4mappingsjoystick
    14 Posts 4 Posters 4.8k Views
    • machine_74M
      machine_74
      Pi Model or other hardware: (B, B+, 2 B, 3, X86 PC etc..) RaspberryPi 3 B+
      Power Supply used: (If using a Pi) Included in kit
      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.4
      Built From: (Pre made SD Image on RetroPie website, Berryboot, or on top of existing OS etc.. - please provide the filename of any image used) Preexisting, see link https://www.amazon.com/gp/product/B07CC86PR3/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
      USB Devices connected: Included SNES type gamepad, N64 stick
      Controller used: LUXMO PREMIUM USB Game Controller for Classic N64 https://www.amazon.com/gp/product/B07QPYSXY4/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
      Error messages received: Buttons do not map correctly
      File: (File with issue - with FULL path) retropie/configs/n64/InputAutoCfg.ini
      Emulator: (Name of emulator - if applicable) Mupen64Plus
      How to replicate the problem:
      Hello experts, I've recently built my first RaspberryPi box for the purposes of trying Kodi as a Plex replacement and to run RetroPie. I have all the ROMS I want and everything seems to be going very well for Nintendo, Atari, etc....but NOT N64.
      I have tried running through the configuration wizard, copying a config I found online...but nothing works. I can select the buttons until the cows come home but they don't work in game.
      I've looked online and can't find anything that works, and these awesome sticks will have to go back if they just don't work. Help!
      Maybe I have it correctly and I need to reload the config, which I thought it did at startup (and failed to remedy itself), but if there's a better way to do this, please reply and I'll be eternally grateful so I can play Goldeneye and Mario Kart with my wife and kids :)
      Thanks for any assistance you can provide.
      The contents of my InputAutoCfg.ini is listed below.. The joystick was detected as a DragonRise Inc. Generic USB Joystick (as purchased says LUXMO) so I copied a DragonRise config off the web--doesn't work. Start buttons, A, B buttons...all don't work.
      Footnote: I believe I am using mupen64plus, but retroarch.cfg does exist in /configs/n64. I believe the InputAutoCfg.ini is tied to mupen but at this point I'll do anything that works.
      ; InputAutoCfg.ini for Mupen64Plus SDL Input plugin
      ; Keyboard_START
      [Keyboard]
      plugged = True
      plugin = 2
      mouse = False
      DPad R = key(100)
      DPad L = key(97)
      DPad D = key(115)
      DPad U = key(119)
      Start = key(13)
      Z Trig = key(122)
      B Button = key(306)
      A Button = key(304)
      C Button R = key(108)
      C Button L = key(106)
      C Button D = key(107)
      C Button U = key(105)
      R Trig = key(99)
      L Trig = key(120)
      Mempak switch = key(44)
      Rumblepak switch = key(46)
      X Axis = key(276,275)
      Y Axis = key(273,274)
      ; Keyboard_END
      ; USB Gamepad _START
      [USB Gamepad ]
      plugged = True
      plugin = 2
      mouse = False
      AnalogDeadzone = 4096,4096
      AnalogPeak = 32768,32768
      Mempak switch =
      Rumblepak switch =
      Start = button(9)
      R Trig = button(5)
      C Button D = button(1)
      A Button = button(2)
      C Button U = button(0)
      B Button = button(3)
      X Axis = axis(0-, 0+)
      Y Axis = axis(1-, 1+)
      Z Trig = button(4)
      ; USB Gamepad _END
      ; DragonRise Inc. Generic USB Joystick _START
      [DragonRise Inc. Generic USB Joystick ]
      plugged = True
      plugin = 2
      mouse = False
      DPad R = axis(0+)
      DPad L = axis(0-)
      DPAD D = axis(1+)
      DPAD U = axis(1-)
      Start = button(9)
      C Button R = button(1)
      C Button D = button(2)
      C Button L = button(3)
      B Button = button(4)
      A Button = button(5)
      L Trig = button(6)
      R Trig = button(7)
      Z Trig = button(8)
      ; DragonRise Inc. Generic USB Joystick _END
      • machine_74M
        machine_74
        I think I did this correctly for reference:
        https://pastebin.com/garijt36
          Can you check the mupen64plus.cfg file (from the same configuration folder) and see how the controllers are mapped to players ? You can paste the files' contents on pastebin.com.
          machine_74M 1 Reply Last reply Reply Quote 0
          • machine_74M
            machine_74 @mitu
            @mitu Glad I reached you.
            https://pastebin.com/MrptqrAA
            Note: This file is listed as mupen64plus.cfg, no "mugen" files in the folder. Attaching screenshot of contents.
            mituM machine_74M 2 Replies Last reply Reply Quote 0
              mitu Global Moderator @machine_74
              @machine_74 said in N64 Controller mappings not working with RetroPie 4.4:
              Who said anything about Mugen ?
              Looking at your .cfg file, the SDL1 is mapped to the SNES controller, while the SDL2 control is mapped to the Dragonrise gamepad (which I assume it's the N64 controller clone). Try switching them in the .cfg file and see if this changes anything.
              • machine_74M
                machine_74 @machine_74
                @machine_74 Will be offline for a few hours but will check back. Thank you very much for any help you can provide. I hope we can get something working and that it sticks so I don't have to recreate every time.
                • machine_74M
                  machine_74 @mitu
                  @mitu It's been a long day, read that wrong.
                  I'll switch it and test tonight. Yeah, the DragonRise is that one.
                  If this does work, how can I go about playing games with two USB pads, and then switch to two N64 sticks, without changing that mupen64plus.cfg file every time?
                    @machine_74 Are they all connected all the time ? I'm thinking pulling out the SNES controller would make the 2nd one be P1.
                    • machine_74M
                      machine_74 @mitu
                      @mitu Yeah me too. Not all the same time. It just occurred to me that this config file is in the n64 section only, so if this works I could make controller 2 have the same config, and then use the existing configs for the NES/SNES.
                      Ideally I would plug in the N64 sticks and the config would work for them, and then swap out and the existing USB pad config would work for them.
                      Also, I don't think I ever used it with the regular pad unplugged as it was the only way I could enter the configuration wizard after things got mucked up.
                      • machine_74M
                        machine_74 @mitu
                        @mitu OK, progress. I unplugged the USB pad and
                        Now if I go through the config and perform the following mappings:
                        D-Pad = directional pad
                        Start = Start
                        Select = trigger on bottom
                        Button A / East = Blue A
                        Button B / South = Green B
                        Button X / North = n/a
                        Button Y / West = n/a
                        Left Shoulder = Left Shoulder
                        Right Shoulder = Right Shoulder
                        Triggers/Thumbs = n/a
                        Left Analog Stick (Up/Down/Left Right) = middle stick
                        Right Analog Stick = n/a
                        Hotkey = Start + Select (trigger)
                        Using Mario Kart, I am then left with a working blue B button which is normally A and no button to back out of menus.
                        After some experimenting, I mapped the green and blue buttons and the closest c-buttons to be E/S/N/W, i.e.
                        Button A / East = C-down
                        Button B / South = Blue A button
                        Button X / North = C-left
                        Button Y / West = Green B button
                        I now have to hit C-down to enter menus in the main screen pre-ROM, but after I get into Mario Kart, the A and B buttons function as they should, and I have to just move my thumb to the C-down to fire.
                        I hit Start and the trigger and it backs me out. Not bad.
                        But.
                        I backed up this configuration and tried to map A and B where I thought it should go and actually have a functioning C-button set for games like the Ocarina of Time, and no go. I put it back.
                        So, I'm going to replicate Joystick #1 to Joystick #2 in the config and give it a whirl, but why is this so hard? There must be an INI with the correct mappings out there, but I have yet to find it, that works on both the menus and the games. Right?
                        • machine_74M
                          machine_74
                          Thanks for your help and advice. I got it working on a config that isn't perfect in the menu, but works great in game. With the other system emulators working fine my only concern right now is the speed of the N64 games, and whether or not I want to attempt to overclock my Pi 3 B+.
                            pegasus1130
                            Has anyone ever figured out how to get the mapping for the Dragonrise controller to work properly? I have been at this for a few days and have had no luck. It is starting to drive me mad that I cannot get this controller to work as intended. After much trial and error, I was able to get it to work without a hot key on the L2 trigger so that it will not restart every time, but now the B button still will not work in game. Additionally, the A is the B button in Emulation Station, then it swaps when I load Mario Kart or the Ocarina of time. I am new to this so any help would be appreciated.
                            mituM A 2 Replies Last reply Reply Quote 0
                              mitu Global Moderator @pegasus1130
                              @pegasus1130 Please open a new topic and add details about your system, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
                                astrotunt @pegasus1130
                                @pegasus1130
                                I am dealing with a similar issue and I am now very, very close to getting it working. I found a post from a year or so ago which suggested that opening the retroarch GUI from within the emulator, then remapping from the "control" menu therein. For me, this involved hitting f1 on a keyboard to bring up the retroarch gui and then switching each button around according to the results of jstest, and finally saving a "core remap file". This let me fix everything but a few buttons. The issue that remains is that there is no listing in that controls menu for buttons 0 and 1, which are my C up and C right.
