    [SOLVED] Audio issues when changing video preview in emulationstation (crackling/popping)
    emulationstatioaudioomxplayer
    6 Posts 2 Posters 849 Views
    • V
      vinz2k
      Hello,
      I’m in retropie 4.5.1, and when i change game in the menu of emulationstation, the sound is crackling /popping sometime.
      It can be reproduce, by opening a console and come back to main menu lots of time.
      Anybody got the same issue ?
      Regards
        Please add more info about your system - https://retropie.org.uk/forum/topic/3/read-this-first.
        • V
          vinz2k
          Thanks for your quick reply.
          Here is the details :
          Power Supply used: official power supply
          RetroPie Version Used : 4.5.1
          USB Devices connected: nothing
          Error messages received: nothing
          Log found in /dev/shm/runcommand.log (if relevant): nothing relevant
          How to replicate the problem : Go to main menu of Retropie, open a console, then the video preview will appear and the sound will start, back to the menue of retropie. Do that in loop, and you shoud hear some crackling/popping noise.
          • V
            vinz2k
            I have a old version of retropie on another sd card, i’ll try to see if it’s the same.
            If it’s working. I’ll maybe try a firmware downgrade to the version just before.
            • V
              vinz2k
              Wrong troubleshooting, it was the same before upgrading RetroPie. (But it’s less hearable in version 3.x)
              So it’s not related with the RetroPie upgrade.
              If anybody got a solution.
              It can also clearly heard when switching quickly the video of screensaver.
              I’ve try to modify some audio option in emulation station but it didn’t solved.
              • V
                vinz2k @vinz2k
                Hello
                Issue is solved
                It was a problem with my amp.
                We can close the issue.
                Regards
