    Unable to boot system (Using different SD Cards)
    retropie 4.5setupsdcard
    12 Posts 3 Posters 720 Views
    • Z
      Zerphane
      Pi Model or other hardware: Raspberry Pi Zero W
      Power Supply used: CanaKit 2.5A Raspberry Pi Micro USB Power Supply/Adapter (UL Listed)
      RetroPie Version Used: 4.5.1
      Built From: Downloaded from website
      USB Devices connected: None
      Controller used: None
      Error messages received:
      The guide used: RetroPie install guide (also have successfully installed systems before)
      How to replicate the problem: I've had issues with 3 different cards, also both RetroPie and Noobs
      I've attempted to install RetroPie/Noobs on several different SD cards and getting better much the same error in all cases.
      I've used SD Card Formater and installed via Win32DiskImager and balenaEtcher and I still get the issues.
      Any help would be great.
      Thank you - Z
        Have you tried to boot a normal Raspbian image ? Do you get the same crash ?
        • Z
          Zerphane @mitu
          @mitu Yes, I've tried both Retropie and the Raspbian, issues with both.
          I've done about a dozen SD cards for systems beforehand (they've all been for Raspberry Pi 3's) and I used Win32DiskImager, and never had an issue. This is the first Zero W I've worked with and the first time I've used Etcher, and now I'm getting fails on several SD cards.
            mitu Global Moderator @Zerphane
            @Zerphane the problem seems to be hw related, make sure you have a proper power source, I don't think the card is at fault.
            • Z
              Zerphane
              @mitu Power Source is as listed in my first post, it's the same one I use to power the Raspberry Pi 3's, I used this supply to build a RetroPie unit on a Raspberry Pi 3 two days ago.
              HalvhjearneH 1 Reply Last reply Reply Quote 0
              • HalvhjearneH
                Halvhjearne @Zerphane
                @Zerphane said in Unable to boot system (Using different SD Cards):
                rofl, here is your problem ... you cannot boot the image from a pi 3 in a pi zero
                • Z
                  Zerphane @Halvhjearne
                  @Halvhjearne I'm very well aware of that, hence why I'm using the Pi 0/1 version. I said I used the power supply of the Raspberry Pi 3. I'm using a fresh SD Card + the retropie-4.5.1-rpi1_zero.img file and tried Noobs as well.
                  • HalvhjearneH
                    this is the first time in this thread, that you mention using the pi zero image ... perhaps check again, if you used the correct image?
                    • Z
                      @Halvhjearne Sorry I thought I did say I was using the Zero W version of the build.
                      I've download - retropie-4.5.1-rpi1_zero.img which is what is downloaded when I choose the Pi 0/1 option on the Retropie site.
                      I've also tried Noobs and Raspbian, they all fail when trying to use the Zero W.
                      I decided to try both cards using a Raspberry Pi 2/3 Build in my Raspberry Pi 3.. and the cards boot up fine, which leads me to believe it's a hardware issue. Anything else I should try or check before I return the unit to the store?
                      Thank you
                      • HalvhjearneH
                        @Zerphane
                        np, i was just pointing out, that it was a very likely, judging from that sentence only
                        it is also possible that this is a hardware failure, if you tested with multiple sd cards.
                        before discarding it tho, i would def try and give the board a good cleanup, to see if you can bring it back to life.
                        • Z
                          @Halvhjearne Well this is a brand new product (Bought it yesterday), I'm thinking of just getting a replacement from the company.
                          • Z
                            Zerphane
                            Turns out it was the unit itself, I got a replacement and it worked right away.
                            • Z
