    Bluetooth problem
    bluetooth4.5.1pi 3 b+freeze issues
    1 Posts 1 Posters 358 Views
      dexter292
      Pi Model or other hardware: Pi 3B+
      Power Supply used: Robition charger 15W
      RetroPie Version Used: 4.5.1
      USB Devices connected: wireless keyboard Logitech
      Guide used: https://retropie.org.uk/docs/Bluetooth-Controller/
      I have trouble when i'm trying to connect Xbox bluetooth gamepad. Iam choosing "Bluetooth" in the preference menu of Retropie then some script is running and it's stacked. I see menu again but device is freezed and not responding at any action
      I've tried:
      sudo apt-get install pi-bluetooth
      sudo apt-get update && sudo apt-get dist-upgrade
      sudo apt-get install raspberrypi-sys-mods
