    **SOLVED** - Trying to install Daphne - Failing with error daphne.bin not found
    27 Posts 5 Posters 12.9k Views
      BuZz administrators
      from terminal - sudo apt-get remove gcc-4.7
      but starting from a new image is an option if that doesn't solve it.
        BuZz administrators
        without removing gcc-4.7 - this may sort it too
        sudo ln -sf /usr/bin/gcc-4.9 /usr/bin/gcc
          Shazam @BuZz
          @BuZz Awesome! That worked! thank you very much! :D
            dthree36
            I would love to get this ROM working too. What version of the ROM did you get to work. I am on Daphine Lairs fans and there are so many different ROM versions available. Just not sure which one to choose.
            FinheadF 1 Reply Last reply Reply Quote 0
            • FinheadF
              Finhead @dthree36
              @dthree36 said in **SOLVED** - Trying to install Daphne - Failing with error daphne.bin not found:
              This IMO is realy nice, uses the full data from the original game the way it should have been.
              Dragon's Lair Enhanced ROM
                Shazam
                @Finhead You wouldn't happen to know where I could get Space Ace from would ya? I've looked all over, and all I find are PC versions - I want to run this on my mame cabinet under Daphne..
                • FinheadF
                  Finhead @Shazam
                  @Shazam
                  Best place to get the 3 games you need actual DVD's for is This Box set have them on ebay fairly cheap as well
