    Need help running roms from USB
    retropielinuxbionic beaverlinux 10.04.3usb roms
    1 Posts 1 Posters 221 Views
    • 1
      1uke_
      Hardware: 10ZIG 58 ThinClient, 1.8GHz intel atom processor, 1GB RAM
      Operating System: Ubuntu Minimal Bionic Beaver 18.04.3 LTS - MATE Desktop
      RetroPie Version Used (4.5.1):
      Built From: Terminal commands / Git clone
      USB Devices connected: 1xKeyboard 1xMouse 1xXbox controler
      1x32B Kingston Data Traveler formated to FAT32 on a Windows 10 PC.
      Hello,
      I have searched the forum for old posts, documentation and I am not getting anywhere with this so hope it is OK to ask here.
      I am trying to get retropie to run ROMS from a USB drive.
      Here is what I have done so far,
      Formated USB stick to FAT32 and added a folder called retropie-mount
      In the Retropie menu
      Retropie Setup > Manage packages > Manage optional package > Install USB Rom Service
      Then
      Retropie config > Retropie set up > Config and tools > USB Rom Service > Enable
      I have then plugged the USB stick in to the computer running Retro Pie
      I left it for a few hours, but then when I put it in my computer I don't see any folders inside the folder on the USB stick.
      (Does it matter that there are no ROMs on the computer running retropie at the moment, should it still carry the file structure over to the USB stick)?
      Any help trouble shooting this would be greatly appreciated.
      Thank you in advance :)
