    HOWTO: Compile Daily Build ScummVM - Solved (in order to play Blade Runner!)
    scumvmdaily buildcompile
    4 Posts 2 Posters 530 Views
      mth75
      Hi all,
      I'm trying to figure out how to compile a ScummVM daily build.
      First problem, I can find the daily's (buildbot bin's), but no Raspbian/Retropie build. I cannot find the 2.1.x betabranch sources.
      Cheers!
        mth75 @mth75
        @mth75
        Solved:
        Change in the scummVM.sh script in /home/pi/RetroPie-Setup/Scriptmodules/emulators/
        the source under "function sources_scummvm()
        the "branch-2-0" source to "master".
          mth75
          The trick to change the source to master doesn't seems to work anymore on a RPI4 install and errors out on the "rip_enable_scalers.diff" .
            mitu Global Moderator @mth75
            @mth75 The patches added by the RetroPie install script work only with the branch/version specified in the script. If you'd like to get the latest dev version, you should also remove the .diff being applied.
