    Problem with standalone Stella
    stellastandalonecut off screen
    5 Posts 2 Posters 889 Views
      polish.potato
      I have a small problem with Stella. The screen is zoomed in too much. The top of the screen is cut off during emulation. This can be proven with Warlords. I was looking to play this with my family on the pi 3 b, with the version 4.5.1 of Retropie. Is there any way to fix it on my own?
      Thanks in the future.
      I was using this on a CRT.
        polish.potato
        13 is my lucky number, can anyone help me with this?
          backstander
          I've never tried my Raspberry Pi on a CRT but you might be able to mess around with Overscan:
          https://github.com/RetroPie/RetroPie-Setup/wiki/Overscan
            polish.potato
            It's just that specific emulator not everything. So how would I just adjust the standalone stella? I also have this to make the crt image a bit clearer on other emus.
            https://retropie.org.uk/forum/topic/18624/custom-configs-for-crt-using-the-built-in-composite-out/87
            I just want to adjust the standalone stella. shrugs
              polish.potato
              The whole problem was the custom config. I had time to reinstall everything and it was the custom config. So yeah there you go.
