    'Zero Delay USB Joystick Encoder' problem...
    joystick error
    5 Posts 3 Posters 995 Views
    • chubstaC
      chubsta
      I have plugged everything in correctly - sanwa style joystick and 6 buttons - but only 'up' and the buttons work, left, right and down do not.
      Checking the board only the red light is lit, I can make the green light come on and switch the red off by plugging a button into the 'mode' socket and pressing it but this has no effect on the non-working directions.
      After banging my head against the wall for a couple of hours does anyone have any clues on this? I did find an old thread with a similar problem but in that persons case there issue was caused by having a button installed incorrectly in the 'mode' slot and that doesn't apply in my case
      Raspberry Pi 400 - overclocked to 2.3GHz
      Theme - Comic book
      Emulators: All of them...
      Roms: Pretty much all of them...
      Favourite games: Circus Charlie, Gorf, Gauntlet Legends
      Controllers: Mayflash F101
      • HalvhjearneH
        Halvhjearne
        @chubsta
        perhaps the controller is in "analog" mode, try switching it to pov mode and try to configure it again?
        chubstaC 1 Reply Last reply Reply Quote 0
        • chubstaC
          chubsta @Halvhjearne
          @Halvhjearne thanks for the reply, I guess that is what is happening with the mode button, but that still doesn’t register three of the directions
          Theme - Comic book
            Clyde
            Did you switch the cables? Maybe some of them are faulty. Or in the worst case, the board is.
            edit: It also could be the switches of the Joystick or their connectors. Try changing around the pieces to see if you can pinpoint faulty ones.
            • chubstaC
              chubsta
              I took everything apart and cleaned all the contacts on the wires, it now seems to work ok, thanks for the help guys
              Theme - Comic book
