    Autostart function not working
    autostart helpautostartrom directory
    51 Posts 5 Posters 6.1k Views
    • RazakR
      Razak
      Does the game start if you enter the line with lr-stella directly in Retropie's command console?
      I get the 'launching screen/ press button to configure menu'
      Where is /dev/shm/runcommand.log and autostart.bat?
        Clyde
        And what happens after the Runcommand menu (i.e. the "launching screen") is shown?
        /dev/shm/runcommand.log is the full path of the file. The first / marks the top of the directory tree in Linux. There's nothing "above" it in the directory hierarchy.
        Sorry, I meant autostart.sh (shame on me for involuntarily typing a Windows file extension 😳 ). It is located at /opt/retropie/configs/all/autostart.sh.
        In the Retropie console, you can display these files easily by adding a cat before them, i.e. cat /dev/shm/runcommand.log, or copy them to your home directory via cp /dev/shm/runcommand.log /home/pi and cp ./opt/retropie/configs/all/autostart.sh /home/pi, if you have better access to that location over the network or otherwise.
        edit: I'm going to sleep now. "See" you tomorrow.
        • RazakR
          Razak
          I get this on the cat /dev/shm/runcommand.log
          Executing: stella
          /opt.retropie/supplementary/runcommand/runcommand.sh: line 1002: stella: command not found
          • RazakR
            Razak
            With /opt/retropie/configs/all/autostart.sh
            I get:
            /opt/retropie/supplementary/runcommand/runcommand.sh 0_SYS_ stella /RetroPi/roms/atari2600/Yar_rev.bin
            It's supposed to be /RetroPie/roms/atari, right?
              Clyde
              As a last quick post before bedtime …
              • Why stella and not lr-stella? The error clearly says that it can't find a command named stella. You should look into that.
              • The path to the rom should begin with either /home/pi/RetroPie/… or ~/RetroPie/…. Your path is missing the ~ at the beginning.
              Good night. 😴
              RazakR 1 Reply Last reply Reply Quote 0
              • RazakR
                Razak @Clyde
                Hi @Clyde
                Hope you had a restful weekend.
                I'm trying this again with another Pi.
                -Have not yet installed Stella on this one. I'm doubting whether that was necessary?
                -I dropped the ROM into /retropie/roms/atari2600/Yar_rev.bin
                -I manually edited the autostart script in Retro-Pie Setup to this:
                /opt/retropie/supplementary/runcommand/runcommand.sh 0_SYS_ atari2600 /home/pi/retropie/roms/atari2600/Yar_rev.bin
                I performed a reboot to the system and when booting back-up I get a screen that states 'launching Yar_rev....press any key to configure'
                I press a key and get to a menu where I can setup video. If I press 'Launch' I'm sent back to the Retropie GUI menu. If I don't press any keys, I'm set back to the Retropie GUI menu.
                The runcommand log; cat /dev/sh/runcommand.logsays this:
                Parameters:
                Executing: Atari 2600
                /opt/retropie/supplementary/runcommand/runcommand.sh: line: 1002 atari2600: command not found
                So the pi knows and attempts to boot into the game, but something happens int the process that makes it crash? Any thoughts on what that may be?
                  mitu Global Moderator @Razak
                  @Razak You mis-spelled the autostart line - there should be a space between the 0 and the _SYS_.
                  • RazakR
                    Razak
                    @mitu Ok, just added the space.
                    And still getting the same results where the runcommand displays a screen like the pic below:
                    And so, now, cat /dev/shm/runcommand.log gives me these results:
                    Parameters:
                    Executing: /opt/retropie/emulators/retroarch -L /opt/retropie/libretocores/lr-stella2014/stella2014_libreto.so --config /opt/retropie/configs/atari2600/retroarch.cfg "home/pi/retropie/roms/atari2600/Yarrev.bin" appendconfig /dev/shm/retroarch.cfg
                    Failed to open /home/pi/retropie/roms/atari2600/Yarrev.bin: No such file or directory
                    By the way, I changed the name of the ROM from Yar_rev.bin to Yarrev.bin out of suspicion that it may have to do with the way the autostart script is failing. Is the runcommand log telling me I need to get lr-stella2014 or that I need to configure something in retroarch?
                      @Razak said in Autostart function not working:
                      Linux is case sensitive, so if the filename doesn't match exactly, then the file cannot be found. The error message is pretty clear - the file is not where you tell the emulator it is.
                      Please post the complete command line.
                        Clyde
                        All hail the all-knowing runcommand.log. 😊
                        At least the retropie in the rom's path is wrong. On a standard Retropie installation, it is called RetroPie. As @mitu said, Linux is case-sensitive, so retropie is a different directory than RetroPie (i.e. you could even have both in the same parent dir). Thus, if the rom's name really is upper case, the path should be /home/pi/RetroPie/roms/atari2600/Yarrev.bin.
                        • RazakR
                          Razak
                          @mitu @Clyde That was it! I should've known and feel like such a dummy. The correct path is indeed /home/pi/RetroPie/roms/atari2600/Yarrev.bin
                          But now I know the all-know runcommand.log :)
                          Thanks a trillion! <3
