    Dell Monitor - 2: Digital - Input In Power Save Mode - Rasberry Pi 3b+
    dell monitorrasberry pi 3b+dvi to hdmi2 digital
    18 Posts 3 Posters 1.6k Views
      mumihp
      Hi All,
      I need help.
      So I brought a cheaper 2nd hand Dell monitor 1907fPT, 19 inch monitor. I have a rasberry pi 3 B+. I installed retropie and got it working on my dell monitor, using a dvi to hdmi connector so DVI cable plugs into Dell monitor while the connect plugs to the HDMI on the Pi.
      It worked. I also brought a VGA to HDMI cable (no connector, just a cable) so I wanted to see if the VGA works. Big mistake as once I took out the DVI and replaced with VGA, didn't work so I swapped it back to the DVI as it seem DVI worked by not VGA.
      However, when I switched back to DVI, all I got was blank screen. with the Message:
      "2: Digital
      Press computer Power button
      or any key on keyboard or mouse move"
      I can hear my rasberry pi working as the back ground music was coming on as I had speakers plugged in but blank screen apart from the message above.
      I first thought, maybe I broke the DVI and HDMI cable when I took it out but I then plugged it in my TV and my 4k monitor, worked perfect, DVI to HDMI cable worked fine and even played a few games on retro pie to test it. (On the DVI end, had the DVI to HDMI connector on, plugged to the monitor and the other end, HDMI to the rasberry pi)
      But for some reason, my Dell monitor keeps showing blank. The reason I brought the DELL 19inch monitor is, I am building a arcade cabinet so wanted to get retropie working before I build it. Bit disappointed as after a few tries and errors, buying cables/connector, finally got it to work on the DELL monitor.
      Also, when I saw the DVI cable was not the issue, I thought maybe the DELL monitor broke so I tested it out, using the same DVI to HDMI cable with my PC and what do you know, it worked, the DELL was showing windows, everything was working so now I know the DELL monitor and cable is working but when you plug into rasberry, I get nothing.
      Does anyone understand why this happened and how to fix it? I am hoping to get this resolved as I really don't want to buy another monitor, I was fortunate to be able to get this monitor on the cheap and it's perfect for my arcade build.
      Summary
      • Rasberry pi 3 b+ works
      • DVI to HDMI works (tested using tv and pc on dell monitor)
      • Dell monitor works as tested with PC
      • Problem: DELL monitor doesn't recognise rasberry but works fine with my PC. Get blank screen and this message:
        "2: Digital
      • Please note, I am a noob when it comes to rasberry pi, so learning things on the go.
        You're confusing things a bit - you have a HDMI to DVI cable (in-HDMI, out-DVI), but that's not so important.
        Can you post the /boot/config.txt configuration file ? It should be accessible either via SSH or by plugging the SD card into your PC (don't format the card if asked) as a boot partition.
          mumihp @mitu
          @mitu said in Dell Monitor - 2: Digital - Input In Power Save Mode - Rasberry Pi 3b+:
          Hi, I copied the text from the config.text
          # http://rpf.io/configtxt
          #hdmi_safe=1
          #disable_overscan=1
          #overscan_left=16
          #overscan_right=16
          #overscan_top=16
          #overscan_bottom=16
          # overscan.
          #framebuffer_width=1280
          #framebuffer_height=720
          #hdmi_force_hotplug=1
          #hdmi_group=1
          #hdmi_mode=1
          #hdmi_drive=2
          # no display
          #config_hdmi_boost=4
          # uncomment for composite PAL
          #sdtv_mode=2
          #arm_freq=800
          #dtparam=i2c_arm=on
          #dtparam=i2s=on
          #dtparam=spi=on
          # Uncomment this to enable the lirc-rpi module
          #dtoverlay=lirc-rpi
          dtparam=audio=on
          gpu_mem_256=128
          gpu_mem_512=256
          gpu_mem_1024=256
          overscan_scale=1
          Thanks for the help
            Try un-commenting the line with config_hdmi_boost so it reads:
            config_hdmi_boost=4
            and see if you get an image when booting. Do you see the 4 raspberry showing up on boot ?
              mumihp @mitu
              config_hdmi_boost=4
              Hi, tried that, see nothing on my screen, I get the digital Input message but when I turn on the pi, screen goes blank and nothing shows up but I can here sound coming from my speakers (speakers which is plugged in pi) but no picture
              thanks,
                Can you run, from a SSH session:
                tvservice -s
                tvservice -p
                and post the output ?
                  mumihp @mitu
                  tvservice -s
                  tvservice -p
                  Hi I don't have ssh enabled, watching a tutorial on how to do it. Since rasberry pi doen't connect to my dell, I have connected to my tv via HDMI/DVI cable and will get ssh enabled before connecting it back to my dell monitor using ssh
                    mumihp @mitu
                    tvservice -s
                    tvservice -p
                    Hi, finally enabled SSH and installed WinSCP on my PC so my pi and PC showing same network. I switched my rasberry pi back to my dell monitor and have SSH ready to use
                    Going to be a noob here, how do I get the output?
                      You need to use Putty, not WinSCP, to run those commands.
                        mumihp @mitu
                        Hi, thankfully I installed Putty before, finally got it working
                        pi@retropie:~ $ tvservice -s
                        state 0x12000a [HDMI DMT (4) RGB full 4:3], 640x480 @ 60.00Hz, progressive
                        pi@retropie:~ $ tvservice -p
                        Powering on HDMI with preferred settings
                        pi@retropie:~ $
                          mumihp @mitu
                          @mitu Also, I connected my raspberry pi to my TV as it works but for some reason, no signal from my pi to the TV. Used the same cable as before but since the changes I made, tv is blank as well, no signal.
                          Regards,
                            mitu Global Moderator @mumihp
                            @mumihp You can back-out the changes you've made (the config.txt modification), but I don't see how that would impact the TV image. The commands you ran are not changing any settings, they only probe and power up the display.
                            What version of RetroPie are you using ?
                              mumihp @mitu
                              Hi, I am using retropie v4.5.1
                              Thanks,
                                Looking at the specs of your monitor, it looks like the native resolution is 1280 x 1024. Try forcing this resolution by modifying the config.txt file with the video mode for this resolution - see https://www.raspberrypi.org/documentation/configuration/config-txt/video.md and look for hdmi_group and hdmi_mode.
                                Add also
                                hdmi_ignore_edid=0xa5000080
                                config_hdmi_boost=4
                                to those configuration and then try again to see if you get any video.
                                  mumihp @mitu
                                  Add also
                                  config_hdmi_boost=4
                                  Hi, it seems my HDMI has stopped recognising anything. Since the changes, pi won't work on my tv or hdmi monitor (did before) so I basically did a fresh install of retropie. No matter what I do, I get the no signal on the tv/monitor. I don't understand if I did a fresh install, surely it my pi should be as I never changed anything so me connecting to the TV or my other monitor should work.
                                  Honestly, it's frustrating, spents hours over the week, tryig to fix it after work. Worked great at first but now, nothing on anything. Atleast if it didn't work on my dell monitor, still could use it on my tv or other monitor but nothing now.
                                    Could it be that your cable or HDMI port are damaged ?
                                      mumihp @mitu
                                      Hi cable works fine, tested it with my other devices but nothing with rasberry pi. I don't know if it broke recently with me pulling it out often but decided to buy a new one, but will wait until the prices comes down, which it should since pi 4 came out recently.
                                      Anyway, thanks for the help.
                                        Stavros7575 0 @mumihp
                                        @mumihp did you managed to solve your problem?
