    Best way too go about a vertical cab build?
    vertical screen
    3 Posts 2 Posters 372 Views
    • chubstaC
      chubsta
      I wish to make a cabinet with a vertical screen for all my favourite old-school games such as Pacman, Donky Kong etc.
      I am aware that there is a significant performance hit if I just rotate the screen by adding the command to the config.txt, so what are my options?
      Raspberry Pi 400 - overclocked to 2.3GHz
      Theme - Comic book
      Emulators: All of them...
      Roms: Pretty much all of them...
      Favourite games: Circus Charlie, Gorf, Gauntlet Legends
      Controllers: Mayflash F101
        Depending on your resolution, the performance hit might not be noticeable.
        Otherwise, if you don't rotate the display, then you'll have to use rotation in
        • Emulationstation (via the --screenrotate option)
        • Emulators - this is up to each emulator used, RetroArch will do this for all its supported cores, I think advmame also supports this (if arcade games are what you're after).
          Of course, everything else will not work - this includes the RetroPie-Setup dialogs and the Runcommand launch menus.
        • chubstaC
          chubsta
          Thanks very much, I wasn't aware that ES could be rotated so that should solve all my issues.
          Theme - Comic book
