    [SOLVED - Updated post to include fix] Portable retropie device blackborders even with "fullscreen mode"
    1upvideo resolutiofullscreenaspect ratiohdmi display
    1 Posts 1 Posters 392 Views
      ahndrooan
      Hello all, new question, same setup:
      Raspberry Pi 3B+
      PSU unsure - 9000mAh
      Version 4.5.1
      Running on Raspbian gnu/linux 9.1.1
      Retrogame pi 1UP Pi Boy device
      Merits of widescreen v original aspect ratio aside, I would like to run retroarch in fullscreen. My device has its own screen as well as the ability to plug into a TV/monitor via HDMi. The retroarch setting changes that I've made are as follows:
      • Start in Fullscreen Mode = On
      • Windowed Fullscreen Mode = On
      • Aspect Ratio = Custom
      • Custom Aspect Ratio Width/Height = 1920(6x) x 1080
      • Windowed Scale = 3.0 x
      • Window Width/Height = 2560 x 1440
        No matter what I do, there's a border around the displayed content. If I increase the custom aspect ratio values, the displayed content gets cut off. Oddly enough, if I boot the device with HDMI plugged in, it goes fullscreen exactly as I want it to but will not do the same when booting without the HDMI.
      As always, any and all help is greatly appreciated!
      [UPDATE] -I'm in an idiot (that's not the update)
      Reading through all related documents, Retroarch Overscan instructions outlines what to do:
      sudo nano /boot/config.txt
      uncomment (i.e. delete the # preceding the line) #disable_overscan=1
      disable_overscan=1
      save with ctrl+x
