    RetroPie 4.5.1 - control and/or emulators lock when attempting to stream to twitch - also, how do I stream to twitch?
    twitchstreaming4.5.1
    9 Posts 2 Posters 1.3k Views
    • E
      etmoonshade
      Pi Model or other hardware: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
      RetroPie Version Used: 4.5.1
      Built From: Source (RetroPie-Setup script on Debian)
      USB Devices connected: Wireless keyboard
      Controller used: Generic XBox controller
      Error messages received: None, unfortunately - here's the runcommand.log from running fceumm:
      Parameters:
      Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-fceumm/fceumm_libretro.so --config /opt/retropie/configs/nes/retroarch.cfg "/home/epsilon/RetroPie/roms/nes/Smb3_576361438584_KJ57E5.nes" --appendconfig /dev/shm/retroarch.cfg
      [libx264 @ 0x55f178c57c40] using SAR=8/7
      [libx264 @ 0x55f178c57c40] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
      [libx264 @ 0x55f178c57c40] profile Main, level 2.1
      [libx264 @ 0x55f178c57c40] 264 - core 155 r2917 0a84d98 - H.264/MPEG-4 AVC codec - Copyleft 2003-2018 - http://www.videolan.org/x264.html - options: cabac=0 ref=1 deblock=0:1:1 analyse=0:0 me=dia subme=0 psy=1 psy_rd=0.40:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=1 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=4 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=2 b_pyramid=2 b_adapt=0 b_bias=0 direct=1 weightb=0 open_gop=0 weightp=0 keyint=250 keyint_min=25 scenecut=0 intra_refresh=0 rc=crf mbtree=0 crf=30.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 pb_ratio=1.30 aq=0
      [matroska @ 0x55f178c62840] Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
      As you can see, no mention of the streaming at all, though the libx264 stuff may be associated. A quick brute-force search of the various log directories doesn't find anything about "twitch.tv" either.
      Guide used:
      Essentially, none. I've looked at the following:
      https://retropie.org.uk/forum/topic/18303/livestreaming-to-twitch-on-retropie-4-4/2
      http://www.retroarch.com/index.php?page=recording
      Especially the latter seems like it should be applicable, but there's no option to set a recording destination. There is, however, the option to add a streaming location with "Twitch" streaming type. I have entered my Twitch key here in the rtmp://live.
      /$YOUR_STREAM_KEY format.
      Relevant config lines from retroarch.cfg:
      video_stream_config = ""
      video_stream_port = "56400"
      video_stream_quality = "1"
      video_stream_scale_factor = "1"
      video_stream_url = "rtmp://live.
      /<stream id edited out>"
      Emulator: lr-snes9x2010, lr-fceumm
      How to replicate the problem: Start up the in-emulator menu, select "Start Streaming" after the above config. SNES loses the controller, NES loses the controller and locks up after about 5 minutes (at least apparently - the music stops. Either way, I need to alt-tab out and Control-C to kill the process.)
      Any insight on whether the old instructions work and I need to do some weird config file edits, or if there's a new way to do things and I'm missing a step?
      (Edit: Updated the topic to encompass both questions - emulator lockup/control failure is the symptom, but the ultimate problem is that I don't seem to be able to stream to twitch)
      • E
        etmoonshade
        For what it's worth, here's a picture of the settings under "Recording..." in RetroArch in case it helps:
        RetroArch Recording Settings
          You may be hitting a RetroArch bug that was fixed a few months back - https://github.com/libretro/RetroArch/issues/8782.
          Can you start with the emulator with verbose logging from Runcommand menu and then post the /dev/shm/runcomman.log to pastebin.com ?
          E 1 Reply Last reply Reply Quote 1
          • E
            etmoonshade @mitu
            @mitu The system was built from the retropie-setup script as of 2 days ago, so presumably whatever I pulled would have had this bugfix already? Maybe it's not working the way I think it should, but I notice it pulling a bunch of stuff from git.
            As for the logfile - hey, look at that, verbose logging. Not sure how I missed that when I was looking for it:
            https://pastebin.com/B7a2fHzs
            Thanks for taking a look.
              Not quite, RetroPie doesn't include the latest & greatest, it's using version 1.7.6 (which doesn't contain the fix). In fact, you can see at the top of the log
              [INFO] [recording] twitch streaming key empty
              which means that it doesn't correctly get the Twitch settings correctly.
              • E
                etmoonshade @mitu
                @mitu said in RetroPie 4.5.1 - control and/or emulators lock when attempting to stream to twitch - also, how do I stream to twitch?:
                Ah-hah. I obviously can't read logs anymore. I blame it on already spending the entire day doing the same. ;)
                Do you have any input on whether I'm likely to brick my setup if I go over to that github and rebuild retroarch from source? It looks like it's just a binary file sitting in /opt/retropie/emulators/retroarch/bin, so I should be able to back that up and drop it in as a replacement... in theory.
                Either way, thanks for the second set of eyes - although I'll be back if it still doesn't work. :D
                (edit: Okay, maybe not back like that - I do understand that this is a bug in the existing retroarch that's bundled with RetroPie, and it'll probably just be fixed on next release - I was trying to be funny, honest :P)
                  You can install the snap/flatpak packages for RA - but to get the latest version from RetroPie, you'd just need to modify the install script - https://github.com/RetroPie/RetroPie-Setup/blob/master/scriptmodules/emulators/retroarch.sh - and in the sources_retroarch function remove the branch number and the patches applied (they won't apply cleanly). See here.
                  Then rebuild RA from source from the RetroPie-Setup menu and re-test your setup.
                  EDIT: Note that if you modify locally the scriptmodule, updating the RetroPie-Setup script will not work. You'll have to reset the modifications with
                  cd $HOME/RetroPie-Setup
                  git reset --hard
                  before updating (it will erase your local modifications).
                  • E
                    etmoonshade @mitu
                    Huh. Okay, that seems simple enough.
                    And hey, look at that, it streams! :D
                    Again, I very much appreciate the help.
                      Thanks for testing, that clears it up.
