    N64 controller not mapping correctly
    n64 controllerbutton mapping
    2 Posts 2 Posters 195 Views
      TheRetroGamer
      I got the exit problem figured out, but I have a problem with the button mapping. I looked at the mapping guide found in Google, but C-down is pretty much useless. Maybe give an easy tutorial on how to manually map the buttons? Because I've been mapping the controller using the main-menu configuration screen, it screws everything up. I am playing this on the emulator.
        I don't know which emulator are you using for N64 and on what system, but what you're looking for is described din the Docs.
