    Need recommendation for a Pi Zero display + button hat
    pi zero hat
    3 Posts 2 Posters 442 Views
    • V
      VictimRLSH
      I have a Pi Zero that is not doing much these days and would like to try a micro build, anyone have a recommendation for a display hat with buttons for this?
      System Config: Retropie 4.4 with full desktop, RPi 3B, 256gb SD, 5v 2.1A 5,200 mAH USB battery. EasyMSX controller mounted with Pimoroni Hyperpixel 4 (non touch). Also running 4.6 on a 4gb Pi 4 serving as my primary desktop computer now.
        StalinIsMyFriend
        Yes. A waveshare 1.3 inch display should be perfect for you! One of the reviews on amazon also has instructions on how to set it up so you are in luck!https://www.amazon.com/interface-Embedded-Controller-Compatible-Raspberry/dp/B07FDQVYFM/ref=sr_1_15?keywords=raspberry+pi+zero+display&qid=1569245359&sr=8-15
        • V
          VictimRLSH
          That one looks really nice, a bit more resolution than the 144x144 hats I've been seeing, and the price is right too.
