    Raspberry Pi Zero Will not connect to WiFi with txt file
    wifiwifi wont connwifikeyfileno keyboardpi zero w
    4 Posts 3 Posters 617 Views
      Twinkie
      I have my pi in a gaming handheld so I can not use a keyboard, so I tried to connect using the wifikeyfile.txt method. When I import wifi credentials It says "unable to connect to network". I have a Linux machine so I was able to add games without WiFi but I really want to scrape box art. Help would be greatly appreciated.
        Please add more info about your system, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
        Is your Wifi network 2.4Ghz or 5Ghz ? The Pi zero can only connect to 2.4Ghz APs. Make sure you don't have any restrictions on your AP to prevent connections from new clients.
          Twinkie
          My wifi is 2.4 ghz. My router is connect to google wifi.
          • N
            Norstein
            A Raspberry Pi Zero doesn't have a WiFi NIC, so not being able to connect to WiFi is the expected result.
            Only Pi Zero W and Pi Zero WH have WiFi NICs.
