    Problem with using controller in-game and keybinding overlay
    10 Posts 3 Posters 3.0k Views
    • H
      halfsaiyan
      I would really like some help figuring out the issue with why the controller i have set up doesnt seem to work when i load a game. it works when im navigating the emulation station but as soon as i start a game it doesnt work. I binded everything correctly, and it seems that the pi is using my controller as the 2nd controller input while the keyboard is my first. The keyboard works in-game but not the controller.
      Ive looked everywhere for this and been working for hours. I read that you are supposed to press f1 and it gets to a menu, but that button doesnt work for me so I did select + X and got to this menu instead, is that the same menu? http://imgur.com/xOJg46u
      Also people said i should be accessing this folder /opt/retropie/emulators/retroarch/configs/gamepad.cfg
      but i have no idea what it means to access it? do i taKe the sd card out of my pi put it in a reader and go through it on my computer? i really need this explained like im 5 step by step i would really appreciate it.
      the other easier problem i have an issue with is getting rid of this key overlay while im in game. shown here http://imgur.com/rk3suve
      • H
        halfsaiyan
        I FIGURED OUT THE CONTROLLER ISSUE I HAD TO PLUG IT INTO THE OTHER PORT IN MY ADAPTER THE ONLY ISSUE I HAVE NOW IS WITH THE KEYBINDING
          GadeEmbossed
          I have the same problem, what exacly is keybinding
          • H
            halfsaiyan @GadeEmbossed
            @GadeEmbossed dunno why i called it keybinding but it shows an overlay of all the keys on the screen its shown in the imgur link
              dankcushions Global Moderator
              you've added some sort of overlay when you were messing around in the menu. so, err. do the opposite of what you did..
              • H
                halfsaiyan
                not sure which menu to go to, or which button it was.. its hard because there are A LOT of options to change around with
                dankcushionsD G 2 Replies Last reply Reply Quote 0
                  dankcushions Global Moderator @halfsaiyan
                  yet you still changed them? :) there's a lesson in here somewhere.
                  I don't know where it is in the menu, but in your /opt/retropie/configs/all/retroarch.cfg and /opt/retropie/configs/psx/retroarch.cfg you want to ensure input_overlay_enable = false
                    GadeEmbossed @halfsaiyan
                    @halfsaiyan How did you fix the multiple controllers to work? :)
                    • H
                      halfsaiyan @dankcushions
                      @dankcushions it seemed like it was defaulted to that.. but im going to try your fix
                      • H
                        @GadeEmbossed well it seems my issue wasnt the same as everyone else's with the controller issue, but I have this adapter USB to ps2 controller that i had plugged into my pi. the adapter has the option for using two controllers, so i just unplugged the controller from one port and plugged it into the other.
