    FBA Neo Romset help?
    fbafba neomame
    5 Posts 3 Posters 1.5k Views
      showstopper
      Hi all,
      I am now looking at getting FBA Neo configured and I need a little guidance on the ROMs. The wiki says that 'ROM Version: Subset of latest MAME/HBMAME roms available' but also says 'Required ROM Version - FB Neo v0.2.97.44'. I am struggling to figure out the required version numbers. The latest MAME ROMs are 0.214, so do i just use clrmamepro to rebuild this romset with the 'FB Neo (NeoGeo only)' DAT file?
      Thanks in advance.
      retropieuser555R B 2 Replies Last reply Reply Quote 0
      • retropieuser555R
        retropieuser555 @showstopper
        This post is deleted!
          barbudreadmon @showstopper
          @showstopper said in FBA Neo Romset help?:
          To get a 100% complete FBNeo romset, you'll need to use clrmamepro with the following sources :
          • latest MAME romset (0.214 indeed, should cover more than 95% of the set)
          • homebrew/hacks from latest HBMAME romset (0.214 too)
          • a few exceptions can be found from older FBNeo/FBAlpha romsets (there are around 20 dumps we never sync with MAME) and more recent MAME romsets (yet-to-release 0.215, i think some chips got redumped last week so there might be 4-5 files like this right now)
            showstopper @barbudreadmon
            @barbudreadmon Thank you for this. For the HBMAME bit is there a list of the files that are required?
              No, sorry, but apart from the few dkong hacks i added a few weeks ago (see https://retropie.org.uk/forum/topic/23549/donkey-kong-spooky-remix-in-retropie), i expect most of them to be also available from older FBNeo/FBAlpha romsets.
