    Joe Montana Football (DosBox) sound effects are static on any SB setting
    dosbox configpc gamessound driversound issuesound settings
    9 Posts 2 Posters 728 Views
    • jamrom2J
      jamrom2
      Retropie 4.4.9
      Pi3B+
      DosBox settings:
      core=simple
      cputype=386
      cycles=4500
      cycleup=10
      cycledown=20
      I've tried everything else under the sun to get better sound effects, but nothing works. Very static, or none at all. I've changed the SB type, port, IRQ, DMA... etc.. etc. Changed CPU cycles, core type, everything.
      Always worked great with DosBox on a PC. Is there something I am missing, or am I stuck using the Sega Genesis version over the PC version?
      Thanks for the help!
      • jamrom2J
        jamrom2
        Some more info...
        I do use seperate config files for all of my DosBox games, so I can manipulate each game individually. I set JMF to a 386 and slowed down the cycles as it ran much better this way.
        The Joystick (gamepad) is super fast even at these settings.
        I had sb16 set, but changed it to this.. and several other sb settings...
        sbtype=sbpro2
        sbbase=220
        irq=7
        dma=1
        hdma=5
        sbmixer=true
        oplmode=auto
        oplemu=default
        oplrate=44100
        Anything else you need, let me know. This is a great classic Football game that I hope to get running at it's full settings and sounds.
          I'm not sure if something is needed besides the default settings. I have a stock Dosbox(SDL2) install and all I did was add a simple .conf file with
          [autoexec]
          mount c: /home/pi/roms/pc-data
          c:
          cd jmf
          montana
          exit
          The game is copied in roms/pc-data/jmf.
          These are the settings in-game:
          Music blasts through and everything seems to be ok.
          • jamrom2J
            jamrom2 @mitu
            @mitu how's your sound effects? Does the title say "Hi, this is Joe Montans... " clearly?
            My music is fine, the sound effects are all scratchy and the joystick is wicked fast
              mitu Global Moderator @jamrom2
              @jamrom2 said in Joe Montana Football (DosBox) sound effects are static on any SB setting:
              It seems so, it's identical to what appears in the video below
              Didn't get that far.
              jamrom2J 3 Replies Last reply Reply Quote 0
              • jamrom2J
                jamrom2 @mitu
                @mitu Yup, that's how it should sound.
                Not sure why mine doesn't unless it's just a crap ROM... which could be the case.
                • jamrom2J
                  jamrom2 @mitu
                  @mitu I have all my dos ROMs in a folder called dos: with pointer ".sh" files in home/pi/RetroPie/roms/pc
                  Works fine in all other games. Here is the 'exe' setup in the jmf.conf file
                  mount c /home/pi/RetroPie/roms/dos
                  C:
                  CD jmf
                  MONTANA.COM
                  EXIT
                  • jamrom2J
                    jamrom2 @jamrom2
                    with a different ROM, my joystick is working good now, but the sound effects are still crap.
                    Same rom works fine in a DosBox session on my PC. Go figure.
                    Not sure what is causing this one.
                    • jamrom2J
                      jamrom2 @mitu
                      @mitu I got it... I updated DosBox and it's working good now. Thanks for your input! I always appreciate how fast you reply to these issues.
