    RetroPie will not load roms with 4.5.1
    mame roms
    2 Posts 2 Posters 304 Views
      Kevintheartist
      Strangest thing happened when I updated to RetroPie 4.5.1. I am running a Pi B+ and when I attempt to open any MAME rom, instead of the rom starting I get a screen asking to choose which emulator to choose. Once I select the default option the rom will run, but if I escape the rom and attempt to run the same rom again, the same menu will appear again. The rom will run again only if choose the menu option. Has anyone run into this?
        backstander
        Try going into the RetroPie Setup Script again and removing then re-installing your MAME emulators. Also do the same with the Runcommand.
        Also it helps if you give us more information:
