    Afterglow Controller Problem
    2 Posts 1 Posters 1.3k Views
      pharv89
      Hello,
      I'm having a problem with an Afterglow controller. The model number is 064-015T. When I configure it using the menu in Emulationstation, everything goes well until I get to the L2 and R2 triggers. They are marked either as "undefined" or a random "Axis" setting. The controller is made for PlayStation 3, but RetroPie seems to detect it as "generic xbox gamepad." I have installed the Xbox driver, but it made no difference. I opened up the controller and noticed that the triggers use a hinge mechanism which looks similar to an analog stick. That might explain the strange "axis" setting. Does anybody know if there is a way to fix this? Or is it just an incompatible controller?
        pharv89
        I forgot to mention that I'm running RetroPie 3.8.1 on a Raspberry Pi 3.
