    Change PC Engine to TurboGrafx-16
    pc engineturbografx-16
    8 Posts 4 Posters 1.6k Views
      showstopper
      I was going to reply to the below thread but it asked if i wanted to create a new topic.
      Re: Any way to show TurboGrafx 16 instead of PC Engine?
      I have created the 'platforms.cfg' file and i have one line in it pcengine_theme="tg16" The file is in /opt/retropie/configs/all/
      I updated the setup script and updated the lr-beetle-pce-fast, lr-beetle-supergrafx cores, rebooted and it still stays on PC Engine.
      Is this working with the latest update?
      EDIT - I am running 4.5.2
      ClydeC quicksilverQ 2 Replies Last reply Reply Quote 1
        I think that you need to re-install of the PC-Engine emulators so that the change is applied to Emulationstation's config.
          showstopper @mitu
          @mitu Thank you for replying. I removed the two packages, and then installed from binary, rebooted and no change.
          Did I do that correctly?
            Clyde @showstopper
            @showstopper said in Change PC Engine to TurboGrafx-16:
            The thread you linked to mentions two lines:
            pcengine_platform="tg16"
            • quicksilverQ
              quicksilver @showstopper
              @showstopper what theme are you using?
                showstopper @quicksilver
                @quicksilver - Sorry guys i dont receive notifications. I am using the comic theme but even with the standard theme it doesn't change
                  showstopper @Clyde
                  @Clyde said in Change PC Engine to TurboGrafx-16:
                  Yeah the wiki says to just change the one line - https://github.com/RetroPie/RetroPie-Setup/wiki/PC-Engine
                  But i did try both and no luck.
                  Do you need to update via binary or source?
                  EDIT - OK the only way i got it to work was to change the es_systems.cfg in /opt/retropie/configs/all/emulationstation/ and change the pc engine theme to tg16, rebooted and now working. Although from what i have read this will get removed when i update.
                  • quicksilverQ
                    @showstopper no that location will not be overwritten. You will have to manually update that file from now on if you add new systems to emulation station.
