    Controller issues N64 emulator (second controller is player 3)
    help and supporhelp gamepadn64 emulator
    2 Posts 2 Posters 360 Views
      KevinKomeet
      Hi guys,
      i have 2 ps4 controllers plugged in the usb ports in the pi,
      but it's reading 4 controllers,
      i've tried to reset the input configuration a couple of times but has the same
      (kind of) problems.
      It's not that big, but with the N64 games the second controller reads as player 3 instead of player 2
      has anyone or had the same issue?
      thank you
      3B+
      Retropie 4. something
      Retroflag superPi case
        I think that's because the 1 PS4 controller appears to generate 2 input devices, so the numbering is skewed. Try the workaround proposed here.
