    [Solved (partly)] - issue with joypad control - How to start Doom Doom2 Heretic ... and all Episodes of Quake (DOPA, ROGUE, HIPNOTIC)
    31 Posts 6 Posters 17.3k Views
      cyperghost
      Hello here is my first post.
      Can somebody please help me. How can I start all the WAD and PAK files that are stored in the DOOM and QUAKE folder in ROM/Ports
      In DOOM-folder i have files:
      • doom.wad
      • doom2.wad
      • heretic.wad
      • tnt.wad
      • plutonia.wad
      • hexen.wad
      I know I can create maybe "DOOM-TNT.sh" and can put command from emulator call from DOOM.WAD to TNT.WAD. But now if I save games from DOOM1 and DOOM-TNT they are all displayed in both games titles togehther. This is a bad solution.
      The same problem exits with QUAKE and the PAK files
      • id1/PAK0.pak PAK1.pak
      • ROGUE/PAK0.pak
      • HIPNOTIC/PAK0.pak
      • DOPA/PAK0.pak
      Is there a quick solution for this probelm?
      Maybe we can add annother arguemnt to our sh.files?
      For ex.
      #!/bin/bash
      "/opt/retropie/supplementary/runcommand/runcommand.sh" 0 PORT quake
      to
      "/opt/retropie/supplementary/runcommand/runcommand.sh" 0 PORT quake hipnotic
      and then the PAK from Hipnotic can be loaded and a save game folder HIPNOTIC is created?
      Thank you
      • ProxyCellP
        ProxyCell
        Hi @cyperghost
        I have pretty much everything working from Ultimate Doom 1, Doom 2 Hell on Earth, FD TNT, FD Plutonia - I have not tried heretic and hexen though...
        I created 4 .sh files in the /home/pi/RetroPie/roms/ports/ for the above that I mentioned and I am using lr-prboom
        weird question: do you have an email address that I can contact you directly at ?
        RPi3b+ - No overclock
        RetroPie - latest from Github, as always
        2x SF30 Pro 8Bitdo controllers
          cyperghost
          Surely I have one email adress :) You are welcome.
          Can you post your bash files here please? Me and maybe some other users find them usefull.
          For Heretic and Hexen - sorry I was wrong. You need PiKiss to run them.
          mediamogulM ProxyCellP 2 Replies Last reply Reply Quote 0
            mediamogul Global Moderator @cyperghost
            @cyperghost
            This previous discussion might be of some help. The troubles that were encountered there can be solved by setting the keyboard localization first.
            • ProxyCellP
              ProxyCell @cyperghost
              @cyperghost Please try what @mediamogul posted and then email myself at proxycell@iruberleet.org
                cyperghost
                @mediamogul - Thank you
                well that's exactly the way I did it - that's why I wrote "create a Doom-TNT.sh and use the emulator call"
                First: it's inconvenient if something in RetroPie changes (maybe a new emulator for DOOM)
                Second: if you create a savegame in first slot for DOOM1 then you see the savegame also in all other DOOM versions. Of course if you load the DOOM1 savegame for a DOOM2 emu for example... the emulator will crash.
                So it would be better to use a file folder for every WAD.... maybe the runcommand.sh can handle a third parameter for loading the specific WAD-file for DOOM-emu and can save userdata in a specific folder.
                @ProxyCell
                I will write you - now I'm on journey
                  @cyperghost said in How to start Doom Doom2 Heretic ... and all Episodes of Quake (DOPA, ROGUE, HIPNOTIC):
                  now I'm on journey
                  Post back with your findings. I'm always interested in improving my setup.
                    cyperghost
                    So back in buisness :-)
                    Well DOOM and all ports works well with for ex. doom2.sh
                    #!/bin/bash
                    /opt/retropie/supplementary/runcommand/runcommand.sh 0 "/opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-prboom/prboom_libretro.so --config /opt/retropie/configs/ports/doom/retroarch.cfg /home/pi/RetroPie/roms/ports/doom/doom2.wad" "lr-prboom"
                    But I'm still not able to run Quake DOPA, ROGUE and HIPNOTIC.
                    They contain one PAK-File (pak0.pak) and even if I rename the folders to id1 the games do not work. The Original Quake-game runs without any flares (id1-folder and contains files pak0.pak (sharewareversion) and pak1.pak (fullversion))
                    ProxyCellP mediamogulM 3 Replies Last reply Reply Quote 0
                    • ProxyCellP
                      #!/bin/bash
                      What about Heretic and Hexen? Were you able to get that going on prboom?
                        I remember there being some trick to it, but it's been a while since I set those up. I'll take a look at mine later.
                          cyperghost
                          No...
                          For Heretic and Hexen you need to download PiKiss and then install Crispy Doom. But I haven't tried so far - there are some tutorials out there that seems working.
                          Step2Step
                          wget https://github.com/jmcerrejon/PiKISS/archive/master.zip
                          unzip master.zip
                          cd PiKISS-master
                          ./piKiss.sh
                          Choose GAMES >> Install Dune2, Drispy Doom, Wolfenstein, Descent.... What you want :)
                          hexen to start HeXen
                          Sorry I haven't tried but it sounds good :)
                            I don't have DOPA installed, as I was only interested in the additions developed directly by id, but for ROGUE and HIPNOTIC to run, they must be located at:
                            /home/pi/RetroPie/roms/ports/quake/id1/rogue/
                            and
                            /home/pi/RetroPie/roms/ports/quake/id1/hipnotic/
                            My launch scripts contain:
                            #!/bin/bash
                            /opt/retropie/supplementary/runcommand/runcommand.sh 0 "/opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-tyrquake/tyrquake_libretro.so --config /opt/retropie/configs/ports/quake/retroarch.cfg /home/pi/RetroPie/roms/ports/quake/id1/rogue/pak0.pak" "lr-tyrquake"
                            and
                            #!/bin/bash
                            /opt/retropie/supplementary/runcommand/runcommand.sh 0 "/opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-tyrquake/tyrquake_libretro.so --config /opt/retropie/configs/ports/quake/retroarch.cfg /home/pi/RetroPie/roms/ports/quake/id1/hipnotic/pak0.pak" "lr-tyrquake"
                              cyperghost
                              @mediamogul
                              Thank you so much for your help. It's unbelievable the error for not starting quake addons was in typing the FOLDERNAME in UPPERCASE even when the original folder is named ROGUE the path in the .sh file should always be lowercase.
                              So Quake orignal is running
                              even Hipnotic nad Rogue now
                              Thank you
                                cyperghost
                                For Heretic and Hexen.... It works with Crispy Doom.
                                #!/bin/bash
                                pushd /usr/local/games
                                /opt/retropie/supplementary/runcommand/runcommand.sh 0 "./crispy-heretic -iwad /home/pi/RetroPie/roms/ports/heretic/heretic.wad"
                                popd
                                Just get PiKiss on your system as mentioned in a few posts of me up. Then create the bash file as written above. It works.... BUT.... No Input possible. I have to find out but hell ... it looks damned good to get those two crackers from id-soft running. Maybe I need help to solve this.
                                Best regards
                                cyperghost
                                • suprjamiS
                                  suprjami
                                  Both hipnotic and rogue work fine using this method so I documented it on the wiki:
                                  https://github.com/RetroPie/RetroPie-Setup/wiki/Quake
                                  I couldn't get DOPA working with the same method. It's freely available at https://cdn.bethsoft.com/quake/dopa.rar if anyone wants to have a go.
                                  • L
                                    leftcog
                                    I found a way to get dopa working. It is a bit weird it involves renaming pak0.pak in dopa folder to pak2.pak and copying over original quake pak files(pak0 and pak1) into dopa dir then using
                                    #!/bin/bash
                                    /opt/retropie/supplementary/runcommand/runcommand.sh 0 "/opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-tyrquake/tyrquake_libretro.so --config /opt/retropie/configs/ports/quake/retroarch.cfg /home/pi/RetroPie/roms/ports/quake/dopa/pak0.pak" "lr-tyrquake"
                                    If anyone knows a better way of doing this let me know
                                    • BriganeB
                                      Brigane
                                      It seems like I'm unable to play full version of Quake with Tyrquake emulator. Even after adding pak1.pak it says "for registered users only". Is this possible to fix somehow?
                                      Systems: Raspberry Pi 0/2/3 Model B+
                                      Os: RetroPie 4.5
                                      Frontend: Emulationstation & Attract Mode
                                      • L
                                        leftcog
                                        You should be able to still enter the portal even though it says that. you could also try replacing pak0 too. Other than that I would make sure you are putting the paks in the right folder. it should be /home/pi/RetroPie/roms/ports/quake/id1/
                                        BriganeB 1 Reply Last reply Reply Quote 0
                                        • BriganeB
                                          Brigane @leftcog
                                          @leftcog I am unable to get through the Portal. I tried to uninstall tyrquake and lr-tyrquake and replace the .pak files again, but still no luck :(
                                          Os: RetroPie 4.5
                                          • L
                                            leftcog
                                            The only thing i can think of is a dual installation try searching root for pak0.pak and see how many dirs come up
